Question about Canon imageRUNNER 5570 Copier
Hi to all i have canon ir6570 model my problem is E824-001 it seems that the primary cooling fan working properly could someone describe the wiring connection of the primary cooling fan
  • Canon Expert
  • 270 Answers
Most likely the primary cooling fan connector has been left unplugged. Open the front door and look under the control panel just to the left of the filter. There will be a gray cover that will have to be removed. This covers the connector to the fan. Remove the cover and check to see if the fan is plugged in. If this is correct then unplug the fan connector and then go ahead a remove the two other screws on the duct on the far right side. Remove the duct and make sure the fan is plugged in to the duct connector. Never had any other problem further in the fan wiring than that.
Posted on Jun 21, 2011
Canon ir6570
A error code E824 is a code for one of the exhaust fans is not turning "ON". I want to say that the code deals with one of the two fans that are in the cover in front of the drum unit. You need to remove the cover to get to the primary & cln corona unit. If they are working correctly, it is going to be the power supply on the right side of the copier. If the fan is failing, you will need to replace the whole power supply, they do not sell it separate. Good Luck
May 15, 2013 | Canon Toner Cartridge For Cnm Ir 6570,...
Canon ir 6570 e 000824-0001
This is the error indicating that the Primary Charging cooling fan is either not plugged in or is not working. Check the connection. I've never had to replace a fan yet. This connection is the one attached to the cooling duct that has to be removed to get to the primary corona assembly. Good Luck.
Sep 12, 2011 | Canon imageRUNNER 5570 Copier
I am having canon ir6570. i have problem E824-001
it is related to primary charging cooling fan.
you canon check the connection of the connector on DC controller board socket NO. J103
otherwise you have to replace cooling fan.
Apr 06, 2011 | Canon Office Equipment & Supplies
6570 - e804-0001
E824 There is a primary charging cooling fan error.
0001 The primary charging cooling fan stop signal has
been detected for 5 sec or more even when the
primary charging cooling fan is on.
Service manual says:
- Check the connection of the connector.
- Replace the fan.
Why did you changed power supply? Did you try with new dc controller?
Jun 29, 2010 | Canon imageRUNNER 5570 Copier
Some lines missing inthe middle of the printout
Check and see if the corona wire cleaner is stuck in the middle of the corona , either transfer or primary corona. Most often it is the corona up top. If it is the cleaner u can move it by loosing gears and turning shaft until it moves to one end of the wire.
Apr 16, 2010 | Canon Office Equipment & Supplies
We have an f105 error what can we do?
Hi...
I Have Canon Ir5570 but i want up speed to Canon Ir6570.
I want Binary file for FRAM COUNTER Board In Chip IC #MB85R256 form Canon Ir6570.
And I want Binary file for Serial Board In Chip IC #BR93LC46F-W form Canon Ir 6570.
Dec 29, 2009 | Toshiba e-Studio 350 Copier
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
Intermittent E0061-0001 on a IR6570 canon
Have you tried to replace the Primary Charge corona unit? How about the rear block for the primary? Try to blow it out.... I did see in the book to try to run DPC in service mode... I also remember on older Canons that some times the wire ties may cause a problem... Also, you say that you are getting background... Is the laser good? Come to think of it I had a IR-5000 do the same thing and it turned out to be the rear corona block for the primary & transfer corona units... Good Luck
Mar 01, 2009 | Canon imageRUNNER 5570 Copier
Canon iR6570 waste toner
look on the right rear of the machine, there should be a door with 2-4 screws. A big white plastic container should be there, remove dump toner and seal bag, replace. Make sure it is sitting properly, it uses a weight system.
Sep 08, 2008 | Canon IMAGERUNNER 6570 Copier
Canon imageRUNNER 5570 Copier Logo
703 people viewed this question
old marine
old marine
