Question about BenQ MP512 SVGA 2200 ANSI 25001 22KG Projector
Start power on, a few minutes the lamp shutdown, tempreture and lamp signal alert.
  • BenQ Master
  • 17,129 Answers
Possible that the filter is clogged on the ventilation fan and must be cleaned and reset.
So remove the filter and clean , check for dirt or obstruction. Check the free flow of the fan to the lamp, if the fan is faulty or not running to the desired speed to cool.
Restart and allow the lamp to be cooled externally to confirm.
Posted on Apr 06, 2011
What cause my picture to start to blink every few minutes
REPLACED SENSOR P# 299P313010A LOCATED BEHIND THE LAMP. TO REPLACE IT, NEED TO REMOVE THE LAMP AND DO IT THROUGH THE LAMP OPENING WITH SMALL PHILLIPS SCREW DRIVER...this can fail causes intermittent shutdown and/or symptom you describe...........good success, meder's tv service
Nov 10, 2013 | Mitsubishi WD Televison & Video
Mitsu hc3000 problem "red-green status light blinking and no input"
Heres what the manual says about REd / green lights
Unplug the power cord from the wall outlet and contact your dealer
And also this:
Check that the lens cap is removed.
It may take about one minute for the lamp to light up.
The lamp fails to light up on rare occasions. In such a case, wait for a few minutes
and then try again.
If the projector was turned off before the lamp was cooled down suf? ciently last time,
the fan may start rotating and the POWER button may not work after the power cord
is plugged. After the fan stops rotating, press the POWER button to turn back on the
POWER indicator.
Check that the intake vent is clean.
Set SCART INPUT in the FEATURE menu to OFF. (See page 25.)
Check that the lamp cover is closed. (See page 33.)
Check that the cables connected to the external devices are not broken.
When an extension cable is being used, replace it with the supplied cable for check. When
images are displayed correctly, add an RGB signal ampli? er to the extension cable.
Check the operation manual of the video device for its connection.
Mar 14, 2008 | Mitsubishi HC3000U Multimedia Projector
AFTER AWHILE TURNS OFF
Locate and monitor the main supply output voltages from the power supply---is one going high after a while--excessive or low output will trigger the latch or shutdown circuit all sets have.
Also suspect a possible issue with poor or bad solder connections anywhere in the set--tapping sometimes will confirm this.
Oct 31, 2012 | Televison & Video
Why does Infocus IN102 projector auto shutdown after a few minutes and indicator light blinks red.
Is it possible to repair the controller board some how? Replacement is not an option because I have approx 100 projectors of this model and X16 lying with me, requiring immediate repairs...
Jan 07, 2012 | InFocus IN102 DLP Projector
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
LCD Display Shutdown After Few Seconds To Few Minutes
Look at the caps in the power supply first, that will be the start.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 06, 2010 | HP L1908wm LCD Monitor
Tv problem
you have a bad board, maybe the power supply/deflection board, maybe the signal board, to troubleshoot this problem you need a qualified tv repairman. or you could replace the whole board yourself, the power supply board is about $200, the signal module is about $500, i'd start with the cheaper one, or hope the repairman can fix it at component level.
Sep 15, 2009 | Samsung HLN4365W 43" Rear Projection...
Sony LCD Projection TV turning OFF.....help!!!
Look carefully at the front lights. Usually when these sets shutdown they have a blink code on either the standby light or the lamp light. Update this with those counts. In the meantime, you may be seeing a problem with heat. If the lamp area gets too hot, the set will shutdown the lamp. Once the area is cool again, the lamp will fire.
Update this and we'll hopefully fix the both of them.
Dan
Apr 09, 2008 | Televison & Video
Lamp goes out
Check your fans, sounds like a thermal shutdown. The fans are 12vdc with a sense line. Red and black power, blue is the sense line. disconnect the fan connector and check the fan with a 12vdc supply. then check the sense line for signal feedback.
Jan 23, 2007 | Optoma EzPro 756 Multimedia Projector
Display goes black after 5 minutes
Repairing the DELL E171Fpc LCD Monitor with the complaint of display shutdown after few seconds (power LED still on) was not difficult. Normally when this type of problem happens, we would first suspect the inverter board, then the filter capacitors and lastly the main board. A defective in one of the lamps and a faulty TL1451AC PWM IC or inverter ic may caused the display to shutdown as well. If the lamp is defective, it will send a feedback to pin 3 or 14 of TL1451AC IC and caused it to stop producing output signal thus the display just shut off once you switch it on.
Dec 09, 2006 | Dell E171FPb 17" Flat Panel LCD Monitor
BenQ MP512 SVGA  2200 ANSI  25001  22KG Projector Logo
268 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
