Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
My 60" rear projection TV
    Problem Solver:
  • 10 Answers
Contact Sony.com and go to Electronics then TVs then Support then write model, select Chat with tech support, complain about your issue and you must receive an offer to get a brand NEW tv for a minimal amount of money to compensate you for the bad quality on your Wega, as result of a class action. I just got it.
Posted on Apr 11, 2011
My 52 " GE Projection
Tv needs to be realined by adjusting the Screen Drive Controls to Tubes.
Located behind the Front bottom Panel on front of Tv.
Focus/Screen Control Block 3 on top for focus and 3 under them for screendives to each Tube R/G/B.
Jul 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
How did I correct blue and red lines curved across a blank screen of my KP-57WV600 SONY Projection TV?
This is for if the lines are thin and arc.
You need to turn down the screen voltage for the blue and red CRT. I don't remember if the focus block is in the front or in the back of the tv on this model. Most projections have them in the front.
You could check the back access panel and look for a black box with six knobs as descibed in step 3 below. This is what you are looking for.
follow the steps below if it is located in the front:
1) Remove the front grill
2) There should be access panel you need to remove once you remove the front grill. This is where the screen voltage adjustment is located
3) Look for a small black box with six knobs on it. One row is for "Focus" and one row is for "screen". It will be marked, but probably need a flashlight to see which row it is. There will be a "R", "G" and "B" next to each knob to represent Red, Green Blue respectively.
4) Careful with the access panel removed, you are only inches away from very dangerous voltages.
5) slowly turn the R or B knob counterclockwise until the lines on the screen disappear.
Keep your hands away from everything else and only use one hand near the tv. put the other hand behind your back.
6) Once corrected, replace the panel and put the grill cover back on.
Feb 17, 2011 | Sony KP-57WV600 57" Rear Projection...
Husband cleaned the dust out from behind tv which caused the blue curve not to line up in which he fixed but now how do you correct the blue curve at bottom of screen?
Check pico fuses in front and behing STK ICs STK392-110s Pico Fuses look like resisotors only they will be Green or Yellow 5amps,6amps 7amp pico fuses.
Nov 29, 2010 | Sony KP-57HW40 57" Rear Projection...
The on and off switch will shut the TV off after
my philips rear projection tv shut down within 1 minute when on rolling the letter av from up to down and curved uo and down also have red lines in screen
Sep 01, 2009 | Philips 50P8341 50" Rear Projection...
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Aug 04, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Faint red curved lines on Sony KP 51ws500.Converged = no work???
Hi There!
This sounds like a typical problem related to a older CRT.
If you remove the front cover of the tv, you can then remove a wood panel. Behind this panel you will see a block (high voltage splitter) it will have 6 "knobs" on it, 3 will say focus, 3 will say screen.
They will also be labeled R - G - B
Put the tv on a blank input so you can see the lines clearly on a black screen  - Find the knob for red, and SLIGHTLY turn it down until the red lines disappear.
Dec 22, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony kp-65wv700
I followed GuestUser/ Slinteriors advice and I fixed it. Open the front of the TV and there are 6 little nobs in the front. The botton 3 are what you need to adjust. from left to right the color controls are BLUE, RED GREEN. For the blue lines, slightly (I really mean very slightly) turn the botton left nob clockwise (right).
Mar 21, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Samsung rear projection 42" green curves causing distortion just started
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
TOSHIBA REAR PROJECTION TV 42H81
you have a convergence problem that will require the replacement of the convergence amp ics.
Nov 29, 2007 | Toshiba 51H83 51" Rear Projection...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
