Question about GE (PSS26MSRSS) Side by Side Refrigerator
GSS22WGPD WW GE Side by Side Refrigerator
Our freezer is not cooling properly. We replaced the thermistor and coil a few months ago. Now we would like expert opinion as to whether we should replace the Damper & thermistor assembly, or is the compressor a good bet on what's wrong? Thanks.
  • 2 more comments
  • decoy 1 Aug 15, 2008
    Damper stays open then closes. If turn control to 5or 6 setting it freezes milk and etc. Can I change out just the damper and thermister or do I need to change board also
  • Anonymous Aug 17, 2008
    Freezer blower gives cool air, but it still does not freeze, There is water pooling outside the door.
  • lukeelong Jan 07, 2009
    ge refrigerator repair not cooling model # GSS22WGPD
  • Anonymous Apr 19, 2009
    what conclusion is reached with the presence of light frost, and what actions should be taken if the observation is negative?
    Champion:
  • 210 Answers
First remove freezer panel in back and check frost pattern on evaporator coil while ref. is running and evap. fan disconnected. should be totally covered in light frost.
Posted on Aug 07, 2008
My water from the front stops working every now and then. I have purged the line. I have tried to hold the water switch in the open state to purge air, but to no avail. I have also changed the filter, to no avail. Can someone tell me what might be the problem..
Posted on Sep 20, 2008
Hotpoint HSS25GFPA WW Freezer not cooling
check for ice build up on evap coils ,,, bad efrost cycle
Oct 05, 2014 | GE Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Trouble shoot the GE GSS22WGPD
the heating element for the self defrost is not working and the freezer is frosting up and blocking the port that sends cold air to the refrigerator side.replace the heating element in the freezer
Mar 20, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge Side by Side Refrigerator model GSS22JFMC ww Is not cooling not frezzing properly and not making ice. The motor is still running ok
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
rggasd
Jul 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My ge side by side model gss25jfmc ww will start to freeze food in the cool side then it stops cooling in the freezer side. Ice will form on the back wall of the freezer. I haved thawed it out &...
I can tell you how to find the problem , but , it is a little work .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off due to temp satisfied .
Jan 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side ref. model # GSS22JFMC WW that is not cooling. A few months ago I replaced the defrosting element. It is not freezing up but for some reason it sometimes stops cooling. I can turn...
First this refrigerator has very low consumer rating. They are plagued with problems with very poor company backing. But without be able to diagnosis the problem in person I would say it's the mother board. And you may find that GE has a new updated board for your appliance. I would go to Amazon.com and search for your motherboard for your refrigerator and read the reviews. Some people leave some great idea. Plus it you bought this refrigerator brand new you can fight with GE to send you a new board.
Oct 29, 2017 | GE GSS22JF Side by Side Refrigerator
The refrigerator and the freezer is not working properly, the food is thawing in the freezer and the refrigerator is not staying cold. The compessor is running and blowing cool air. It just started...
Possible defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.Since you've already replaced the motherboard Checkdefrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE not working
Change the defrost heater, It's located at the bottom of the frosted coils and should have a pink and blue wire running to it.
Jun 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
801 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
