Question about RCA L37WD12 37 in. LCD HDTV
Tv just all of a sudden started flickering - RCA L37WD12 37 in. LCD HDTV
I did that an its still the same way its flickering...
Posted on Oct 02, 2011
  • 101 Answers
Could be that the lamp might be getting old, or maybe a small surge from the wall, or any magnetic field being created in the house, like the air conditioner turning or vacume cleaner.
Posted on Apr 06, 2011
Flickering Sharp Aquos tv
it really depends on were the flicker is, if its the backlight or the screen, flicker can mean them both, t-con board only controls the screen out put on lcds, but on plasmas it works with the back light inverters. if the screen is white and not flickering while looking at the back of the screen on an lcd then it could be the t-con board failing it could also be a bad connection to the board from the wires. the plug were the main board connects to the t-con board if you have the back off and wiggle the cable and see if it stops the flicker.
Aug 08, 2017 | Sharp Televison & Video
Flickering screen like bad flouresent bulb
you need to remove the back cover of the tv to gain access the internal part. and then you need to look if their is a loose contact or dry joint connector at the power inverter board for the screen back light. if the connection is good then their is a flickering the back light is need a replacement.
Nov 12, 2012 | Televison & Video
My Vizio picture was great. All of a sudden the screen started flickering. I was able to change the channel but it was still flickering. I shut off the directv receiver and the problem was still there. ...
The tv buffer boards for the tv backlight,the X or Y buffer boards it is dead or dying.Take it to the tv shop,for a propper diagnoise and price estamate to changes the wright tv buffer board.
May 08, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
I was wathing tv when my light started flickering then the tv turned off now it wont turn back on please help
Hello, This is a sudden high voltage, it will require opening the television to check faulty component. First check for fuses in the printed circuit board and if found replace with same current rating. Also check other component such as the power transistor, resistor, rectifier with a multimeter set at ohms range
May 20, 2010 | Televison & Video
FLICKERING BACK LIGHT
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Mar 25, 2010 | Televison & Video
Flickering picture
Can you please check the model number, what is listed is not valid for a Sony. This could be a simple fix or something expensive. With the model number, I can provide you with details.
Thanks,
Dan
Apr 16, 2008 | Televison & Video
Screen/Picture Flickering
alo all..
i got problem wif my TV... sony wega trinitron 29inch..
- last 2 night... the TV @ screen slowly lost color for 2-4second... and after that it suddenly turn off for 5-10second and turn back on itself. the led blink 3-5times....
what the problem to my TV?
Jan 09, 2008 | Sony KP-46S25 TV
Picture is not stable
Check the Power Supply board to see any puffed capacitors. If found faulty cap, replace them.
Jan 05, 2008 | Polaroid FLM-2632 Television
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
RCA L37WD12 37 in. LCD HDTV Logo
358 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
