Question about Dynex Optical Mouse
When i plug my dynex wired mouse into the usb it says unknown device. it worked before it just suddenly stopped.
  • 36 Answers
Have you changed your operating system?
Have you tried plugging it into a different USB port?
Go into the Device Manager By right Clicking "My Computer", Click "Manage", then go to the Device Manager Tab. Right Click the USB driver for the Mouse if it is there and Uninstall it. Then try plugging it back in afterwards.
Posted on Apr 06, 2011
  • 4 Answers
It may be your drivers are uninstalled.So you can install them again to make your mouse run.
How do i change the battery in dynex wired optiical mouse model dx-wmse2
if the mouse is wired to the back of the computer by a usb plug then there will be no battery as the mouse is powered through the usb connection.
Jan 24, 2015 | Dynex Usb Wired Optical Mouse
My Genius Traveler 6000x wireless mouse suddenly stopped working
Double check the batteries, although the lights work and the computer sees it, the voltage could drop low enough to stop the sensors.
next, try another USB device in that plug. USB port can go bad.
If the port works, it could be the wireless USB connector starting to fail, if they are bumped to hard sideways it can cause loose connections internally.
then, you might just need to update drivers. Computer update s can conflict with drivers cause devices toss top working.
May 20, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
I have a usb wired dynex optical mouse, i just bought a Toshiba sattelite laptop and external mouse does not work when i plug into usb port
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a buuon or switch on top or bottom
hope this helps
Jul 01, 2011 | Computers & Internet
I have compaq 610 laptop window7 . frequently external usb mouse stopping to work as well as showing that one usb device attached with this computer, window is not recognising it. By clicking i knew that...
hey Windows 7 stated, first time here in days, nobody ever tells OS.
you are a winner for savvy award 1000
old relic COMPAQ LT.
your LT now has 2 mice, and if you run 2 mice what happens
they try to get in a fight.
we must shut off the mouse pad first.
I guess this mouse is a MS mouse, no mouse name stated.
I shut off the mouse pad in device manager.
look for the USB mouse not, is this unstated mouse wireless, if yes a new battery is now needed. and matching usb dongle.
now plug in the mouse. PC goes DING donng.,
and it loads a driver
be in the internet to W7 can find the driver.
if still dead, go to device manager,
see that mouse there under. mice and other pointing devices
mine shows, HID mouse here.
if missing , plug the mouse into all USB ports 1 by one and listen for the DINGDONGg (means new USB device discovered)
if still fails buy a new mouse, gee barrow one for a day.
if that mouse works , trash the dead one.
you can not have 2 mice at same time or you get into trouble.
the old mouse pad , we had to use disable in device manager to kill it.
on the new HP we have newer driver and it has this.
" tab, automatically disable pad mouse with usb mouse active"
but old ones dont have this
I too hate pads. when the thumb hits the pad, I want to kill that pad fast.
one ebay a 5 pack of mice is $14
a 5 year supply, all mine fail in 1year, the wires snap near mouse inside, easy;
Jun 18, 2017 | Compaq Computers & Internet
When I plug in the usb for Dynex Keyboard, it doesn't work.
Sounds like you've got a bad keyboard.
You should contact Dynex direct for in-warranty replacement.
You can reach them here.
  • usflagicon.gif1-800-305-2204
May 25, 2010 | Dynex Multimedia Keyboard
My touch pad suddenly stopped working it was working fine until yesterday
Plug an usb wired or wireless mouse and check to see if it was disabled in the control panel. does it show up in device manager?
Feb 21, 2010 | Sony VAIO VGN-FJ270/B Notebook
My USB is not recognizing my wireliess mouse divice.
try to check if is it properly installed not just the hardware but as well as the software. Basically when we plug in a usb deice especially first time you inserted that device it sometimes need allowable time to install its driver. Also try to check if you computer supports plug and play device such as USB cause sometimes not all USB device are supported in all different types of hardware.
Jun 16, 2009 | Dynex Wireless Optical Mouse
Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Jan 22, 2009 | Dynex Wireless Keyboard/Optical Mouse...
Dyne Mouse Problem
a mouse doesn't need a special driver, try uninstalling it from device manager and refresh.
or plug in to another usb port.
Mar 08, 2008 | Computers & Internet
Dynex Optical Mouse Logo
353 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
