Nokia 3230 Logo
Posted on Aug 06, 2008
Forgot of memory card password
I have forgot my memory card password. i dont know how to retrive it on using nokia 3230 model. Can u give suggesion to my problem..
A
Anonymous
Check help in the mobile but as far as i know u need to take it to the nokia shop to get it done
After formating nokia 3230 memory card is locked autometically
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
May 13, 2010 • Nokia 3230
Hi Sir=)
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Mar 21, 2010 • Nokia 3230
16helpful
3answers
I forgot the password of micro sd card
better u download elock or ilock software from net in jar format..use tat software and lock ur folder
1helpful
Sir i gave password for my nokia 3230 mmc memory card to protect against illegal use. but unfortunately i dont remember the password,so I am unable to use my memory card. please help me unlock it
Install and launch MMCPWD application. It will display some special characters including your password.
Option 2:
Locate mmcstore file. Install and launch System Explorer or FExplorer application. Go to c:\system\ and open (using unicode/hex editor) the mmcstore file. it will display your password. NOTE: you can also copy the mmcstore file to any folder of your phone memory, rename it to mmcstore.txt and open it without using any unicode/hex editor).
Option 3:
1. Open up fe explorer thingy.
2. Go to C:\system\ folder and locate a file called mmcStore. Scroll down till you find it.
3. Copy it to C:\nokia\others
4. Highlight it
5. Click options
6. FILE>RENAME
7. IT should turn blue: right click then write ".txt" (should look like "MMCSTORE.txt"
8. Try to open it, (that should be your password, if nothing happens then go to 9.)
9. Connect phone to pc
10. Open the file from C:\NOKIA\OTHERS\MMCSTORE
11. Copy the file to your desktop
12. Open with Windows notepad/ microsoft word
13. That should be your password
May 06, 2009 • Nokia 3230
2answers
How can format the phone memmory of NOKIA 3230
Download user guide from:
http://nds1.nokia.com/phones/files/guides/Nokia_3230_UG_en.pdf
Page 163
Formatting the memory card
When a memory card is formatted, all data on the card are permanently lost.
Some memory cards are supplied pre-formatted and others require formatting.
Consult your retailer to find out if you must format the memory card before you
can use it.
• Select Options→ Format mem. card.
Select Yes to confirm. When formatting is complete, enter a name for the
memory card (max. 11 letters or numbers).
Backing up and restoring information
To back up information from your phone’s memory to the memory card, select
Options→ Backup phone mem.
To restore information from the memory card to the phone’s memory, select
Options→ Restore from card.
You can only back up the phone memory and restore it to the same phone.
Locking the memory card
To set a password to lock your memory card to help prevent unauthorised use,
select Options→ Set password.
You are asked to enter and confirm your password. The password can be up to
eight characters long.
Your rating would be most appreciated.
Feb 20, 2009 • Nokia 3230
1helpful
I want break my memory card password
1. First Install FExplorer in your phone memory.
2. Got to drive C: , you will find a file called mmcstore
3. Send it to your pc directly and open it in notepad or rename the file.
4. At the end of the file you will find your password.
7helpful
2answers
there is no way to break if the password is forgotten for the memory card, but u can attach the card to the memory card reader to the computer and format the card and u can use it
Nov 08, 2008 • Nokia 3230
45helpful
7answers
Please Unlock my MicroSD password.
I forgot my MicroSd password.Please help me to remove it.I am unable to access my MicroSD card.I have Nokia 6300
989helpful
37answers
Memory card password remover
i have nokia 5310. i cannot remove my password of memory card because i have forgot it. i have no idea about password.so it cannot be remove so please give me a solution
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
