Question about Acer Aspire 5600 Series 5630-6951 Laptop
Wireless not working when ac adapter plugged in
Hello, my acer 5630 laptop will not view any available wireless networks when the ac adapter is plugged in. as soon as i remove the ac power adapter, it finds the networks. how can i solve this?
  • skendrix Aug 09, 2008
    Yes! It was indeed changed. Curiously, the Acer Power Management program was showing the Wireless Lan to be turned on. However, right clicking on the toolbar icon showed the Wireless Lan to be unchecked. So, I clicked on it (now checked) and it works again! Thank you kindly.
    Problem Solver:
  • 8 Answers
It looks like you've changed the settings to turn off the wireless when AC adapter is preset. Try going into Acer Power Management and make sure Wireless Lan is selected on your Power Plan.
-Aaron
Posted on Aug 08, 2008
SOURCE:
Acer aspire 4250 wireles problem (may due to adapter setting.
Connecting your Acer laptop to your home wireless network is fairly simple.
Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position.
Not all models have this switch.
Open the Windows Start menu and select "Connect To."
A list of available connections will appear.
Select "All" from the drop-down menu to view all available networks and connections within range.
Select the desired network and click "Connect."
Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Windows 7 Acer AspireLaptop wireless
Wireless Internet is a convenient way to hook up multiple computers to one router without the mess of cords.
The router or 2-in-one (router/modem combo), must be set up through your Internet Service Provider and connected with either a DSL line or Cable.
Since most Acer laptops have built-in wireless, no additional hardware is required.
Turn on the laptop.
Move the switch located on the front of the laptop to the right, then let go.
The switch will go back to its original position.
Confirm that the wireless networking icon has appeared on the screen.
Right-click the wireless icon in the bottom right corner.
In Windows 7 this will resemble a small stair-step triangle; In Vista it looks like a tiny monitor.
Click "View available wireless networks."
It might also say "Open network and sharing center."
Wait while the adapter finds your wireless network.
Click to highlight the network and click the "Connect" button.
Enter the security password that you created when setting up the router (if applicable).
If you don't know or can't remember, log in to the gateway page specified in the user's guide.
Locate the "Wireless security" settings page to see if security is enabled.
If it is, type in a new key and enter the same number for the wireless network.
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire1300/Aspire1300faq27.shtml
Feb 19, 2014 | Acer Aspire 4520-5582 Notebook
WIRLESS NOT WORKING
First turn on your wi fi switch on laptop.
Then go to my netowkr places proeprty and make sure your wi fi network adapter driver is installed and enabled.
Then click on view available wi fi networks then check you get signal form wi fi router.Then it works.
Let me know if you need more assistanse.
Aslo you can check in router that wireles is enabled in router?
For that connect your wi fi router to computer with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
typoe user as "admin' and password as "admin" or blank or "password"
then check in wireless settings that it is enabled.
Thanks.
Sep 24, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 5360
Please make sure that the wireless antenna switch is on. Then enable the wireless feature using the hot key combination for your laptop (if available but need not be done since you were able to detect networks earlier). If you are using Vista, please click on Start-Connect to to see if your laptop is now able to detect networks.
If laptop is not able to detect any networks, please uninstall the wireless network adapter by going to Start - Control Panel - Classic View - Device Manager - Network Adapters - select the one for the  Wireless Network Adapter - properties - driver tab - uninstall - ok. Then please restart your laptop. Click on Start - Connect to  and see if your laptop is now able to detect networks.
If laptop is still not able to detect wireless networks, please click on Start - All Programs - Accessories - System Tools - System Restore then choose a restore point (date) which is a possible time when your laptop was able to detect wireless networks. Laptop will restart automatically and notify you if the restoration is completed. Try Start - Connect to. Hope it works this time. Thank you.
Sep 30, 2008 | Acer Aspire 5630 Notebook
Acer laptop not conneted to 2Wire147 Moderm
make sure you turn on the wirless on your laptop. Could you see this wireless under view wireless available wireless network??. When you say will not connect, you already see it or no ???
Apr 28, 2008 | Computers & Internet
WIFi Connection
change channels to 1-6-or 11
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection1.gif Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones1.gif and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Jan 17, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5600 Series 5630-6951 Laptop Logo
133 people viewed this question
Ekse
Alun Cox
