Question about Intel Computers & Internet
I have no video controller (vga) compatible, my pc resolution is low, the tab will not work.
  • 36 Answers
Check your computers Casing for a model number, Go to the website for your brand of PC and go to their Support section. Go to Drivers and Downloads and specify your model, then download the Video driver and install it.
Posted on Apr 06, 2011
My pc will not work with my 32" tv screen it says
Without knowing the brand / model of the TV, PC video card, or Windows Operating System, I can only offer a general suggestion of trying a different resolution of the display on the PC.
Right-click an black area on your desktop, and click on "Properties". Click on the Settings tab to display the options shown below:
Adjust the "Screen resolution" slide control in the "less" direction (in the red circle) and then attempt to send the screen to the TV again. Repeat as often as needed until a workable set of resolutions are found.
If unable to get a display, provide the info asked for above, and include the length of the VGA cable and any adapters used.
Oct 05, 2011 | Televison & Video
I have very low resolution.
Hi betty2293,
Low resolution on your desktop can be for two reasons ,
  1. You have chosen a low resolution from your desktop properties, you need to check this up , by right clicking anywhere in a free area of your desktop , then selecting properties --> settings tab and then you find an option to change the resolution.
  2. If you don't find multiple options to select that means, it's because of no video drivers installed.
  3. Therefore you need to use your motherboard supplied CD to install the VGA/Video drivers and things should work fine for you and you will be able to find multiple resolutions in your settings tab which I described above.
Hope this helps...:)
Aug 23, 2011 | Computers & Internet
My son was on my computer and change my video mode and turn off my computer and now it say that it can not display the video mode optimum resolution 1024x768 60Hz
Please reboot the machine. After it beeps hit F8 repeatedly. You'll get
a menu. One menu item will be "vga mode". Choose that, and use
the control panel to A) set 800x600, boot normally
or B) try setting your normal mode. Hope this helps even a bit.
Apr 16, 2011 | E-Machines eMachines Desktop PC
Vga card
high resolution is supported by high resolution monitors or LCD no matter what type of Video card are you using so first check monitor compatibility with the resolution
Oct 05, 2009 | EliteGroup K7SOM Motherboard
Display Problem
Okay you need a display driver for you video card, you did not say what type of video card you have so its hard giving you a url that is not going to work. if the video is onboard go to the gigabyte website and download that driver you will have success with this if you get the correct driver. Thanks and please rate
Aug 19, 2009 | Gigabyte GA-8LD533 Motherboard
Envision L19W761 LCD TV - VGA mode failure.
The resolution or refresh rate of the computer is not compatible with the TV. Before the computer starts loading Windows, start tapping F8 and select "Enable VGA Mode" from the menu that appears, this will set your computer to a very low resolution (640x480). I believe the option is actually called "Enable low resolution video" on Vista, it's VGA mode in XP. Now you should get a picture on the TV, work your way up from there.
Jun 26, 2009 | Envision L19W761 19 in. LCD TV
Video controller
You are using the built-in video driver provided by Windows. You need the video driver from E-Machines. You can download that here.
Jun 02, 2009 | E-Machines (T2958) PC Desktop
My VGA is very low as low as 4 bits and I cant fix it.
You need to locate and reinstall your video drivers - most likely showing up in Device Manager as VGA compatible or other device. After installing will appear as Display Adapter and allow higher resolution.
Dec 11, 2008 | Compaq Business d530 (PB185US) PC Desktop
Connecting lenovo t61 with samsung ln40a650
The LN40A650 supports 1920x1080 resolution from VGA. I know this because I've done it. It will also support lower resolutions, but certainly not higher. Drop your resolution to something low like 640x480, plug into the LN40A650, then up the resolution to 1920x1080. If this doesn't work it's 1 of 2 problems. It could be the refresh rate. Go to your display settings, click on Advanced, choose the Monitor tab, and set the screen refresh rate to 60Hz. If this still doesn't work it means your video card won't support that high of a resolution.
Sep 12, 2008 | Televison & Video
Windows XP Home Edition
try going to HP web site, you can download the specific driver for your VGA graphics card, if yours is the CTO notebook it's the intel 82852/82855 GM/GME Graphics controllers driver. If not, go direct to the HP drivers page and you can select the exact model VIA there. Also had other software drivers if you are having problems with other hardware.
Apr 29, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
126 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
