Question about Multiquip GA25H 25kW 120V Honda GX160
My honda engine is idling up and down - Multiquip GA25H 25kW 120V Honda GX160
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
I understand this is a 2200 / 2500 W generator with an automatic idle control and that you have a 5.5 Hp GX160 engine
Perform the following:
1. Turn off the fuel selector
2. Remove the float bowl nut and bowl
3. Dump the bowl contents
4. In the threaded area where the bowl nut screws into the carb.... there is a Brass orifice. Use a thinner than usual standard screwdriver and remove the orifice / jet. As you look at the screwdriver handle inverted rotation for the jet removal will be clockwise. There s a pin hole in the orifice.... clean-out the pin hole but DO NOT poke anything into the jet hole and make it bigger. Just clean it thoroughly. Hold it up to the light and look for the pin hole after cleaning.
5. Before reinstalling the jet / orifice spray carb cleaner up into the hole your removed the jet from.
6. Also before installig the jet... briefly turn on the fuel selector and watch for fuel flow from the float needle area with the float DOWN. Gently raise the float with one finger to horizontal and make sure the fuel flow stops. Then make sure fuel flow starts again when lowered. No fuel flow here = problems from the fuel tank outlet to the fuel mainifold on the carb. (can be a clogged fuel filter if so equipped) Also some fuel selectors have a mini-bowl under them. Unscrew the mini-bowl if you have one and remove the debris. Pull the hose off the carb fuel manifold fitting and check fuel flow again by briefly turning of the fuel selector. If you have fuel here and no fuel at the float needle then the manifold is clogged and you will have to remove the float and needle then spray carb cleaner into the float needle hole watching for carb cleaner to shoot out the fuel manifold fitting.
Reassemble float and needle along with reattaching the main fuel hose to the fuel manifold fitting.
7. Reinstall the orifice / jet.
8. Reinstall the fuel float bowl and nut.
9. Fuel selector on and check for leaks.... min 1 min pause
10. TEST engine performance now.
11. If the problem persists then the most likely suspect is the automatic idle control assembly. For troubleshooting... grip the governor arm and hold it steady to see if the engine maintains a constant speed. If by holding the governor arm still you have a constant engine speed; you have a bad automatic idle control.
Unless the automatic idle control is failing....the cleaning procedure above usually brings them back to normal operation.
Thanks for choosing FixYa,
Kelly
Posted on Apr 06, 2011
1994 Honda Civic DX I Replaced Idle Air Control Valve Because Idle Was Jumping Up And Down The New Valve Jumps And Down To And when i Disconnect The Valve Car Idles Fine ?
Erratic Idle On Civic - YouTube
? 0:53
https://www.youtube.com/watch?v=sEiTi5GAcrQ
Jan 29, 2010 - Uploaded by stikkyp
My 1994 Honda Civic SI has an erratic idle. It stays at 3000-3500rpm when started cold till it warms up then ...
High idle and constant up and down idle on my 94 civic ex? ' Yahoo ...
https://answers.yahoo.com/question/index?qid...
Oct 27, 2011 - Okay so im learning lots about Honda's, i have rebuilt motors and put them but i cant ... It has a constant up and down idle between 1200 and 2000 rpms. ...to a near stall for a fraction of a second, then jumps back up, like clockwork. ... No coil packs on your 1994, of course - just one coil and a distributor. Rpm jumping up and down at warm up 1k to 2k 97 honda prelude ...
Jan 11, 2014
why does my honda civic idle up and down?
Apr 22, 2010
1994 honda civic Idle problem?
Dec 17, 2009
rpm of my honda accord goes up and down when in park or ...
Mar 8, 2009
More results from answers.yahoo.com
Idle goes up and down! HELP! ' ClubCivic.com - Your Online Civic ...
www.clubcivic.com > ... > Engine Tech / Drivetrain
Jan 09, 2016 | Honda Cars & Trucks
Honda Civic the idle on car idles up and down manly when stopped
When an engine just idles fast and slow, it's usually a vacuum leak somewhere. You can spray on the hoses carrying engine vacuum to see the leak.
Hope this helps.
Mar 25, 2015 | Honda Civic Cars & Trucks
2013 Honda Activa will not idle when warm
Hi, Anonymous you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda Activa 2013 Engine Stalling
Honda Activa Engine idling stalling issue caused by faulty ring fitment...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda activa 2009 Owner Manual
Jun 28, 2014 | 2011 Honda Activa
What is the map sensor code for a 1992 honda accord
1. yes a 1992 Honda accord has a map sensor and what accord do you have engine wise ?? because theres different codes 2. it could be a idle air control valve because if they get dirty they can cause the car to rev high low or even stall and cause the car to run crappy.
Apr 23, 2014 | 1999 Honda Accord
1979 Honda CBX will not idle
The engine should be at operating temperature with the choke off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air-fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air-fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air-fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air-fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1979 Honda CBX Cold Start and Idle
Lazy Slow Return to Idle or Erratically High Idle
Honda 1979 CBX Shop Manual
1979 Honda CBX Owner Manual
Apr 19, 2013 | 1979 Honda CBX
Idles fast problem
That would be your engine "choke" functioning. It's not a problem. The choke engages when engine is cold and shoots extra fuel to the cylinders to idle the engine up especially in cold with. Once the engine has sufficiently warmed up, the engine will idle back down.
Jun 20, 2012 | 1987 Honda Accord
My 1992 honda accord idles up and down when it
it will do that, it is normal, should go between about 600 and 1500 rpm...
----------- thats just a normal warm up cycle, it will change the engine speed and mixture as combustion gets better with the heat.
Jan 16, 2010 | 1992 Honda Accord
Idles up and down after warm up
THE COOLANT LEVEL IS LOW
on the older hondas even the newer ones idle speed is coolant temp controlled.
when the engine idles up the electronic coolant temp sensor is submerged in coolant and reads warm, so the engine computer idles the car down. the coolant level if low than drops from around the coolant temp sensor and it says the engine is cold, so the engine computer idles the car up.
which results in the constant rise and fall in engine rpm.
ADD COOLANT TO THE RADIATOR AND WATCH THE CAR MAGICALLY FIX ITSELF.
Apr 10, 2009 | 1993 Honda Accord
Multiquip GA25H 25kW 120V Honda GX160 Logo
2,017 people viewed this question
Top Multiquip Electrical Supplies Experts
JonSnell Electronic
JonSnell Electronic
Lucy Angela
Lucy Angela
Are you a Multiquip Electrical Supply Expert? Answer questions, earn points and help others
