Technics SA-GX470 After playing music for almost two hours, my Technics SA-GX470 stopped music and started showing "OVERLOAD" in the display. It did not function after that, but showed the same message even after power off and back on. Please help to understanding this and suggest potential fix for it.
  • 682 Answers
Over load means your speakers and its cable----please check it for bad cable or bad speaker------try to insert speaker one by one and test each time to investigate the bad one.--------if every thing is ok and you keep good ventilation around your receiver (no blocking of ventilation holes)and you still have a problem your protection circuit in your receiver needs to be checked by service technician
Posted on Aug 06, 2008
I have a technique sa-gx470 amplifier that says overload the moment its turned on. I just went thru it and gave it a thorough cleaning and nothing changed still says overload when turned on. Does anyone...
You probably have a Technics amplifier. If you check some of the answers in that category, one of the fixya experts may have responded to that earlier.
Jul 05, 2014 | Audio Players & Recorders
Overload display
Follow the course of the capacitor using the printed circuit board track. It should leave to an semiconductor (IC or Transistor). Replace that. As that will be causing the cap to blow.
Apr 26, 2014 | Technics SA-TX50 Receiver
Overload
Probably dry joints around the power amplifier.
Mar 18, 2017 | Technics SA-AX720 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
I have a technics sa-gx470 and when I power it on,the display reads (tuner,then the station,then reads overload) Is there a way to reset this unit??Or is there something that might have quit working?
Check for bad solder connections on the voltage regulators (attached to the heat sink)
It also could need an output IC (not cheap if available)
Oct 20, 2009 | Audio Players & Recorders
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Receiver overload problem
The overload message is indicating that a problem was found and the system is shutting down the output section to prevent further damage. There are probably poor connections on the main board and failing capacitors in the front end. Expect a parts vcost in the $10 range. Add in the local labor rate for the total repair bill.
Dan
May 23, 2008 | Technics SA-DX930 Receiver
Technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Nov 30, 2007 | Technics SA-EX300 Receiver
900 people viewed this question
 Grubhead
Grubhead
