Question about Whirlpool DU1030XTXS Dishwasher
Water fills, pump trys to start 2 or three times, cycle stops, drain cancel light comes on, water drains
  • 213 Answers
SOURCE: Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Posted on Nov 20, 2007
  • 101 Answers
SOURCE: Dishwasher is full of water
The drain pump needs to be replace.
Posted on Apr 26, 2008
SOURCE: Whirlpool dishwasher will not start
There is a small replacable part on the control panel circuit board which is like a fuse. It actually is a temperature fuse and it blows when the environment gets too hot for the circuit board. Unplug the dishwasher and take the door apart so you can see the circuit board. If you trace the power wires one of them leads to a little white module with 2 electrical tabs. Unplug the 2 wires and unsnap the module. You can check it with an ohm meter. IF its good the meter will register almost a short. f it's bad it will be open. The parts place I went to didn't even need a model number and he says he goes through a lot of them.
Posted on Nov 09, 2008
  • 111 Answers
SOURCE: Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Posted on Jun 20, 2009
QueenJLyn
  • 3 Answers
SOURCE: Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Posted on Aug 01, 2009
Not finishing cycle
Is it draining out the water?? Dishwashers fill, spray, and drain more than several times during a cycle. After starting a cycle, let the unit fill, start spraying, and then cancel the cycle--listen for the drain pump activating and pumping out the water. If water is not being drained properly(within a certain time limit), the unit will error code out and stop. Also, make sure the filter is clear--if it gets clogged with "muck", enough water won't be sprayed onto the dishes properly, the pump will require too much energy to try to pump water, the control will sense this and shut down the unit to protect it.
Jul 25, 2015 | KitchenAid KDHE704DSS 24 6-Cycle/7-Option...
WHirlpool wtw6600
HI,
Unplug your washer and open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass through it should not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there should be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire FDP635RFR3 wont drain.
Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
Apr 28, 2010 | Dishwashers
Dishwasher not working. lights come on but dishwasher will not start. when you hit cancel/stop, 2 minutes appear and there is a huming sound and it counts down and goes off. When u turn on the wash cycle,...
the dw is probably full of water because the motor didnt pump it out
because the impellor on the motor has stripped thread and not drainning the water when u hit cancel /stop the timer is asking the d/w to drain and end the cycle. If u wait 2 mints after u start the machine do u then here a hum from the motor trying to wash
if the d/w dosnt have water in it and you turn it on it should fill or there is a problem with the inlet water valve or timer or no power to the water valve a appliance tech should determine this probably more than normall person should attempt
( solv ya prob)
Oct 18, 2009 | Kenmore Dishwashers
Kenmore elite dishwasher model 665.16293402 will not start cycle
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Whirlpool DU1030XTXS Dishwasher Logo
26 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
