Question about Casio Watches
How do i adjust the analogue part of my watch as i cannot find the instruction booklet. i have done the digital part but have tried using all the different buttons with no luck. look forward to your assistance. model number 3793 aq-180w as per back plate
    President:
  • 2,501 Answers
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Apr 06, 2011
I cant fix the analog of my watch pasnew model PLG_1002AD GRADE A QC 6
Ignore the instructions I found its not as easy as they say first you need to sync the digital and analog to do this press all four buttons at once and hold for 3 secs tho sets the digital clock to 12 Now press mode till you see h-s hold reset till h-s flashes hold the start button in the analog will start moving its slow so be patient set analogue to 12 exactly ignore the minutes that have passed press preset the minute hand will automatically adjust once done press mode go to the main watch screen hold preset use mode to select hours minutes date year month etc and start to change the values keep it on 12 not 24 hour clock set the clock and press preset the analog will now automatically adjust to the time once done you can change to 24 hr mode if you wish
Mar 06, 2015 | Watches
The directions in the booklet don't make any sense. I cant change anything.
press and hold the lower right button, the digits blinks(blinking means changeable) use the "mode"/the lower left button to choose what digits are you going to change. the upper right button is use for adjusting. if your done just press the lower right button. i hope i had been helped you
Sep 12, 2011 | Adidas ADH6079 Watch
How to set the time for casio aw-591(4778) details about mode,adjust ,reverse and forward
press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
Sep 08, 2011 | Casio Gshock G Shock Analog Digital New...
I have a Waveceptor 3353. If I change time zone I can usually set the watch to show ,say, Paris time both digitally and in analogue. When I try to go back to my home time zone, London, the second hand...
If you cannot find the automatic way of setting the hands, you can manually reset the analogue hands by pressing the mode button until you reach the "HS" mode and using the 2 or 4 o'clock buttons to adjust the hands.
Dec 30, 2010 | Casio DW9051B-1V Wrist Watch
Setting analogue time on a Crane & Viceroy Radio controlled watch
I haven't been able to locate your watch but since watches tend to be similar in operation, I suggest that you look at the instructions for my watch and try a similar settings.
Go to "http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2735.pdf" and instructions for a Casio watch will appear. Go to page 4 and read instructions under "to adjust analogue time".
Mar 30, 2010 | Watches
Can't adjust the date on a digital watch
These are the instructions for the AD0721. They might apply to your model, too. I hope this helps:
http://img261.imageshack.us/img261/6784/manualr.jpg
The analog setting of the watch takes place by pulling out the knob (kind of tough) and adjusting, like a regular analog watch. The analog and digital displays are will NOT stay in sync, unfortunately.
Good luck.
PC
May 26, 2009 | Watches
Have a casio watch with analogue and digital time.  can change analogue time but not digital time
Digital time must be set using pushbuttons on watch case sides. One of them is for MODE, another for SETTINGS.
Mode button usually must be held pushed in for a while to start to work and the digits should start to flash - only then you can start to reset your digital watch using another (settings) button.
Use small steal pin to push these buttons.
If nothing happens, you will have to consult your nearest watch repairer as in this case there is a mechanical or electronical fault.
Rating is very appreciated.
Jan 05, 2009 | Watches
Seiko Sportura SNJ007 chrograph watch instructions
Best solution is to download the ORIGINAL INSTRUCTIONS MANUAL directly from SEIKO's main website:
http://www.seikowatches.com/support/ib/index.html
Aug 25, 2008 | Seiko Sportura SNJ007 Wrist Watch
Citizen Skyhawk Time Adjustment Problem
It is possible to set the main analogue hour and minute hand 30 minutes out of phase with the digital readout, but doing so will also put the analogue UTC dial 30 minutes off. It can be done by using a variation of the proceedure for zeroing the watch hands as follows: 1. Rotate the crown in its normal opering position to set the watch in chronograph mode (mode dial pointing to "chr") 2. Pull out the crown to the second click. This should cause all the hands on the watch to return to zero. "HR" should appear on the left-hand digital display. This will allow you to move the hour hand by twisting the crown. Advance it to about half way between the 12 o'clock and 1 o'clock positions. 3. Press the top button. "MIN" should appear in the left-hand digital display. This allows you to adjust the minute hand. Twist the crown to advance it to the 6 o'clock, or 30 minute, position. Note that this will also move the minute hand on the small UTC dial to the 30 minute position. 4. Press the crown back into its normal position. 5. Reset the digital time and date according to a time zone that is in a one-hour offset from UTC. This is not a perfect solution. Your digital readings will show the correct time for all one-hour offset time zones while your analogue nads are 30 minutes out of phase. Your small UTC dial will also be 30 minutes out of phase with the digital UTC. Hope this helps.
May 28, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
405 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
