Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Unable to print code 50
I have checked the user guide on line but there is no reference code 50 or code 30 which it also seems to show. I've removed all paper jams and have turned the printer off for 1 hour hoping it would reset itself. Resently put refills rather than Brother ink cartridges. Is there anything else I can do
Yup, had a paper jam, removed the offending piece, turned printer off and on and raised and lowered lid and did everything possible to resolve (any other printer would have been fixed), but ooohhh nooo, now I only get "unable to print error 50" and same with "error 30". What the heck do these error codes mean??? How do I fix my printer???
  • 13 more comments
  • ladywatts Aug 21, 2008
    Now I get error 30, after checking voltage and plugging into different outlets, bypassing power strips, and turning on and off. Still no go on printing.
    Checked for any small bits of paper...none. Getting an error code 30 now.
    Tried solutions offered and now getting an error code 30.
    Well, I have already updated the software and I have repeatedly turned the printer off (unplugged it as well) for extended periods. Still getting error code 30.....I am about to scream in frustration!!!
    Fuse lamp??? And I do not have an HP printer. It is a Brother MFC 440 CN. And I found no reference to error code 30. As I am not a repair type person (far from it!), if error code 30 is the same as error code 50, the fuser or fuse lamp or whatever, I am not sure how I would go about fixing this problem anyway. How difficult is it??? Should I just throw the printer out???.
    Still getting error code 30. And I am sorry, but page 30 does not have troubleshooting. Could not find the troubleshooting in the pdf file sent.
    Didn't help.
    What exactly is error code 30?? Anyone really know???
    Just error code 30....and absolutley NO piece of paper anywhere to be found and even my husband had a look...no paper. Brother MFCs must just be pieces of junk if a little paper jam does this to them!!! Our old HP printer has had several paper jams and just removing the paper cleared the problem immediately. What gives with Brother?
    Thanks, but now getting error code 50 again.
  • ladywatts Aug 22, 2008
    Sigh.....nada...error 50 still lives.
    Thanks, everyone, I have had it for today with the demon printer from hell. Still nothing but errors 50 and 30...maybe tomorrow.
  • ladywatts Aug 23, 2008
    Well, nothing has worked and I am giving up. None of the experts could help me with my problem, though they all had good suggestions. The last solution was to bring in expert technical help. Too much trouble, too expensive, will bite the bullet and get a new printer...an HP this time.
  • lebong Nov 27, 2008
    Just the same as ladywatt. I had a paper jam. After removing the paper and turning the machine on and off (both long and short periods), I get nothing but the old "Unable to Print 50" notice.
  • eiluj_3 Jan 31, 2009
    I get the -30 error code when I print to PDF and then try to open it.
    Master:
  • 638 Answers
What error code do you receive? Is it 30 only or does it toggle between 30 and 50 (watch some more 5 minutes!).
Anyway, two solution for this named errors:
1. Only error 30:
There IS some paper piece left inside the printer. Mostly could this be found on the very very left side (seeing from front as in normal use). Open scanner and have a good look into the edges. You will find a small piece of paper left there.
2. 30 and 50 (toggling)
See here same issue:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge browser window to see pic some what better).
Posted on Aug 21, 2008
  • 157 Answers
Looks like the printer is using alot of ur time trying to fix it.
Looks like its faulty and it might be time to upgrade because it will be too
I think that is the best fix becuase it will be too expensiv to fix
Cheers
JigSaw
Fixya Team
Posted on Aug 24, 2008
  • 1,879 Answers
Those error messages that you're getting is a sweet way of telling you that the printer is KAPUT.
For example :
Paper Jam but there's no paper inside - it's the paper sensor malfunctioning.
Cartridge not recognized - it's not the cart, the "cart sensor" stopped sensing anything.
Error code ## - the logic board that we are not sure what it's supposed to do is also malfunctioning.
Hope this clears up
Posted on Aug 22, 2008
  • monk3ybidzness
    monk3ybidzness Aug 22, 2008
    The above information applies to those error codes that manufacturers website & tech support reps can't even give you the exact answer.
    If the error codes can't be found in your user manual & manufacturer's website OR from their tech reps, it means service or replacement.
  • monk3ybidzness
    monk3ybidzness Aug 23, 2008
    "Resently put refills rather than Brother ink cartridges."
    That caused the problem in the first place. Hope you don't do the same with your next printer.
  • 876 Answers
Try this simple reset:
I'll bet you are a little frustrated by now.
Turn off your printer and unplug it.
Open the paper jam door and gently push the paper roller forward until it clicks
Close the door
Plug your printer back in
Turn it back on.
Hope this helps. Thank you for using Fix Ya
  • Gayle Ashbach
    Gayle Ashbach Aug 22, 2008
    Error Code E50 means that the fuser unit has been damaged and needs replacing.
    Brother's toll free customer service number is 1-800-284-4329. They can tell you what you might do to verify this diagnosis. and slos what E30 means which I do not know.
    For the closest service center to you- you can call this number 1-800-284-4357 for that information.
    Good luck to you. I hope that you have an answer soon to this problem, and I regret that I could not be of more help to you.
    Thank you for using Fix YA!
    Genius:
  • 1,050 Answers
You stated that you replaced the cartridges with refills.
This is sounding like you have a bad smart chip on them, or it will not accept refills.
I suggest getting OEM new and going from there
  • Coss Aug 21, 2008
    An error code 50 can also be a damaged fuser.
    But you said you are only getting an error code 30 now.
    The 2 can be related. If there is a small piece of paper stuck down inside the fuser (the only way you would be able to see it is to remove the fuser and inspect)
  • Brother Master
  • 19,396 Answers
Error 50 on Brother is paper Jam, open the door at the back and check again, a small fragment of paper may jam the printer.
    Genius:
  • 1,665 Answers
Http://static.compusa.com/pdf/Brother-MFC-440CN-Printer-Manual.pdf
have a look at page 30 for troubleshooting
  • 2,071 Answers
Just click below;
Printer and Photocopier Troubleshooting and Repair Collection ... refill of BJC-620 ink cartridges. Inkjet Printer ... HP LaserJet series II - error code 50 Service and clicking. Notes on HP LaserJet II error code 50 ... Hopes this may help; Regards, VOTIT
  • LORETO LACARON
    LORETO LACARON Aug 22, 2008
    Problem:
    During printer warmup cycle a 50 error message is displayed on the LCD panel.
    Cause:
    90% of the time this is caused by a burnt out quartz fusing lamp (Click here for information on how to test the fusing lamp). The DC controller does not see the fuser get up to operating temperature and produces the error message.
    Solution:
    Replace the necessary parts, all of which are included in this repair kit (along with easy to follow directions).
    Kit Includes:
    • Quartz Fusing Lamp
    • Fully illustrated instructions for easy installation
    Difficulty Level:
  • LORETO LACARON
    LORETO LACARON Aug 30, 2008
    Latest updates of the problem!!!
  • 6,487 Answers
Try updating your printer's software , that should fix that problem.
Then power cycle your printer meaning turn off the printer for about 5 minutes then try it again...
Hope that helps.......
  • 4 more comments
  • Mark Gil
    Mark Gil Aug 21, 2008
    Did you already update the software of the printer? just to make sure your using the latest software..
  • Mark Gil
    Did you try uninstalling and reinstalling the printer? since you have now a different error code better uninstall it ....
  • Mark Gil
    When you generate a custom form as a .pdf document, an error occurs: "Error Code -20, -30, or -40. Printer not activated." That's what error 30 is...
  • Mark Gil
    It seems the your printer has alot of problem and it will be better to have this printer replace from Brother...
  • Mark Gil
    Mark Gil Aug 22, 2008
    Sorry if we cannot fix it at this moment feel free to contact us back on your free time...
  • Mark Gil
    Mark Gil Aug 23, 2008
    Sorry for that , but I think that's the best thing that you can do now is to get a new printer...
    Master:
  • 521 Answers
Check properly if a small piece is still remaining it will show that error.while removing the paper the paper sensor has been moved.because you would have pulled the paper hardly.adjust that lens below the paper feeder gears.this may solve it.thanks.please rate the solution.keep me updated.
  • 2 more comments
  • tech expert12 Aug 21, 2008
    just click the link and solve it on your own.
    http://www.repairfaq.org/sam/printfaq.ht...
    if the paper jam is on its lens.it will definately show this error.and hp is much better choice then brother.
  • tech expert12 Aug 22, 2008
    technical help at your place is much advisable.as if some thing goes wrong in decoding this minor errors.some major error can occur which cannot be solved as thecircuit board of the printer will be corrupted.thanks.
  • tech expert12 Aug 23, 2008
    Master:
  • 623 Answers
50 PRINTER ERROR
A problem exists with the customer’s line voltage.
1. Remove the printer from any UPS supplies, additional power supplies, or power strips.
2. Plug the printer into a wall outlet and see if this resolves the problem.
3. If the printer is already plugged into a wall outlet, try another power source in the building that is independent of the one currently being used.
4. The line voltage and current source at the printer location might need to be inspected to ensure that it meets the printer’s electrical specifications.
  • 5 more comments
  • ritchie dempacco
    ritchie dempacco Aug 21, 2008
    50 FUSER ERROR
    A fuser error has occurred.
    1. Turn the printer off, wait 10 minutes, and
    then turn the printer on.
    2. If the message persists, reseat the fuser.
    If that does not work, replace the fuser.
    To check the fuser, turn
    the printer off and remove the fuser. Measure the resistance between
    the fuser connectors.
    If it is not within the proper range, replace
    the fuser.
    If there is not continuity between the fuser connectors
    neutral and hot with the fuser removed, replace the fuser.
    If the
    problem is not related to the fuser, replace the engine controller
    board.
  • ritchie dempacco
    good luck
  • ritchie dempacco
    try my solution
  • ritchie dempacco
    it might help
  • ritchie dempacco
    try my solution
  • ritchie dempacco
    ritchie dempacco Aug 22, 2008
    try my solution it might help...
  • ritchie dempacco
    50 PRINTER ERROR
    50 FUSER ERROR
  • 68 Answers
Try to visit thier website of your printer then specify the error code 50,...then try to do what they would say...
thanks
    Genius:
  • 1,268 Answers
Give this a try..
* Go to Printers and Faxes, right-click your printer and Disable
* Turn off printer (unplug the power)
* Carefully Remove All Cartridges
* Wait for about 5 mins. Turn on printer without cartridges.
* Leave it on for about 2 mins. Turn it off.
* Put the cartridges back in then turn on printer.
* Go to Printers and Faxes again then Enable the printer.
Check if you can print now.
THE LCD SCREEN SAYS PRINT UNABLE 50 AND SEE TROUBLESHOOTING AND ROUTINE MAINTENANCE CHAPTER IN USERS GUIDE.
Read the users guide and do what they say in the Troubleshooting and Routine Maintence Chapter for the "Print Unable 50" error message.
Mar 29, 2011 | Office Equipment & Supplies
Print unable 30 & print unable 50
I had the same problem. I got a sledge hammer and hit it till there was nothing left. Then I bought a new printer. Takes the frustration out of the fix
Jan 26, 2009 | Brother MFC-5460CN All-In-One InkJet...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
put the right print cartridges in from Brother...brother
Aug 20, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will not print
www.brother.com has those user guides by model number..
Jul 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Not printing
my printer doesnt work, what do i need to do so that i can use my printer again,pls kindly give me the information, it always said that go to the maintenance and routine maintenance chapter. i have no any idea on that device, pls!!! thanks!!!
Jul 03, 2008 | Brother DCP 130C All-In-One InkJet Printer
i got a brother printer dcp135 ,but it got a error (print unable 51)
how i settle it???
thx...
May 29, 2008 | Brother DCP 130C All-In-One InkJet Printer
Error message 50 and 30
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Apr 04, 2008 | Brother MFC-845CW multi-function...
Print Unable 50 Brother MFC5460 CN
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
614 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
