If i want to enter ringing tone and to select the phone will off and restart
    Novelist:
  • 144 Answers
Hi there!
the phone goes off and restarts by itself when you try to choose/set a ring tone? its possible that the ring tone file is missing or corrupted. or if that ringtone came with the cellphone when you bought it, try removing the battery for a minute, put it back in, turn on the cellphone and see if the same issue happens, you may wanna have the cellphone look onto by a technician because its already a hardware issue i believe =)
Posted on Apr 06, 2011
Automatic switch off while selecting ring tone settings,
SOLUTION FOR YOU
1. Click on Menu 2. Go to Settings> Restore Factory Setting 3. Enter the code (Default code is 12345) if changed enter the changed code. 4. Press OK to restore all the settings. 5. The phone will restart, and now the problem will be solved.
Hope this Helps.
May 19, 2011 | Nokia 1650 Cell Phone
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
Nokia 1661 my phone not ringing why ?
Mar 22, 2010 | Nokia 1661 Cell Phone
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
How to change the incomming ring tone on panasonic kx-t7630
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
  • Press 'Prog'
  • Press 'Intercom' twice
  • Now you can either go through the different ring tones by pressing 'SEL' on the LCD screen or using the Up and Down keys on the circular pad on the bottom right of the phone.
  • Once you have the tone you like click on 'Enter'
  • Pick up handset and hangup to complete the process.
Dec 04, 2008 | Panasonic KX-T7630 Corded Phone
Message alert tone
hi there ,
             you have to enter settings , tone settings, then you select loud , then select loud details , you can change the message tone , the alert tones , the ring tones from there.hope this helps..
Simon
Sep 04, 2008 | Motorola Mobility RAZR V3i Cellular Phone
NO RINGING TONE
hi!
check your mobile is in silent mode!
After that goto tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume!
or
Otherwise goto profile personalise setting tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume
Good luck
Jul 18, 2008 | RIM BlackBerry Pearl Smartphone
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
