Question about Garden
Hi I have a plasmacem 30 and I cannot get an arc, the machine used to work (several years ago) but has not been used for sometime. Just wondering on any suggestion for trouble shooting, thanks in advance, Peter
  • 10,319 Answers
If stored in a unheated garage all electrical contacts need to be cleaned.
Posted on Apr 12, 2011
Bernina Record 730 - made in 1965ish. Recently he has started sewing very slowly although the bobbin winder worked normally. We cannot find out why this is happening.
Oh, no! Do NOT give up on your oldie but goodie! The symptoms are common with older mechanical machines. These machines are wonderful and deserve to be given another chance. Most often, the old oil solidifies and causes the moving parts to seize. With persistence, patience, and a couple of very simple supplies, many of these machines are happily sewing again. The secret is a combination of Tri-Flow and heat and making sure that "all" the moving parts get lubed, even the stitch levers and dials. I have resurrected several older Berninas using the following technique. Several completely seized machines required multiple repetitions over a period of days. If the machine does not have any cracked gears, most likely it can be made worthy again and make your grandmother proud that she gave you such a lasting, wonderful gift.
Resist the temptation to try to run the motor until the machine has gone through a thorough "treatment" and is moving freely manually. Once the machine is moving freely, you will rejoice at the happy and satisfied sound it makes!
Good luck with your lovely!
Wheel on right side that controls the needle up and down is very tight...
How can fix stuck needle bar on my Bernina 730
Nov 28, 2016 | Bernina Sewing Machines
When the welder is first turned on I can weld with gas for about 5 seconds. Then the breaker trips. ( i have the proper wiring and breaker). The more times I reset the breaker the shorter the weld time...
Hi:
Just make sure that if you are using an extension cable between your machine and the power outlet, this cable is at least a 12 gauge size, if you are using a 14 or 16 it's too small to handle the amps.
Other point is to check that your breaker is 20 or 30 Amp capacity.
Hope this help.
Sep 08, 2011 | Clarke Power Products Clarke 130EN...
I have a Quantum XL-1 that apparently has a broken timing belt.
I have an Quantum XL 1000 Singer Sewing machine that needs a throat plate. I am in need to find this piece. Please can you help?
Jun 10, 2009 | Singer Quantum XL-1000 Computerized Sewing...
No memory card with my 5700
Janome USA has this Dealer Finder webpage, just enter your post/zip code.
Best of......
www.bargainbox.com.au
Nov 19, 2008 | Janome Memory Craft 5700
K5A refurb/repair
First thing check the carbon brushes, when they wear out they arc at the armature. Two black screw covers one either side of the top motor housing. The brushes are keyed to only go back in one way so make a note of which corner of the brush has been shaved off. If you look in the hole with a torch you can see the little blocker in one corner deep down. As a rule it's back top corner on one side and back bottom corner on the other side.
Oct 21, 2017 | KitchenAid K5SS Heavy Duty Commercial...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
