Question about D-Link DFE 2624 Networking Hub
Two d-link hubs do not communicate - D-Link DFE 2624 Networking Hub
    Scholar:
  • 125 Answers
Hubs don't have the brains to communicate without help. They're more like a splitter than a switch is. If you're not using static IP's then the best thing to do is plug them into a router or a managed switch capable of assigning IP addresses. Also, be sure you are using the correct cabling. Conventionally, hubs are to be hooked up with straight cables and switches with crossovers, but in today's auto-sense world that's rarely an issue. In any case, be sure you are using the "Uplink" port when attaching a hub to another piece of networking equipment. Try assigning everything static IP's or using a device with DHCP to act as a brain. If these suggestions don't help please post more information about what it is you're trying to accomplish. Good luck.
Posted on Apr 06, 2011
I have a 8 port ethernet switch DES-1108 how do i connect it to a DSL cable modem and the 3 computers i have . do i need to use the router still. or what
If the computers only need to communicate with each other then you do not need a router.
Each of the computers must have the same Network name (workgroup) and have the same IP address range. If you have a fixed IP address on each of the computers the IP address range should be the same - for example 192.168.3.xxx (xxx being a number unique to each of the computers, BUT the first 3 group of numbers (IP address range) MUST be the same on all the computers.
If the computers need Internet access then a router is required and if there is insufficient LAN ports on the router then you need to add a network hub connect the router to tht hub and connect the computers to this hub. You would need to configure the computers to obtail an IP address automatically, the router will issue IP address to the computers automatically.
I would not recommend using the Ethernet switch with the router as it would require a more complex configuration.
May 13, 2011 | D-Link DES-1108 8-Port Ethernet Switch...
Reconecting the cables to the hub does not make a network
Not necessarily! As long as a lan cable is connected on the wan port of your hub and the other end goes directly to the modem, the connection is correct. The remaining port will be left for the lan cables of the computers. No orders needed. Just make sure that lan cables was properly seated on the port. The LED blinking in the hub will tell you if its working or communicating with your computer. Find it, when the LED is not lit or blinking, the lan cable is not connected properly on the hub (or the other end of the lan cable is disconnected from the lan card of the computers).
If all cables are connected properly and still cannot connect to the network, you may need to refresh the name of the workgroup on the computers that cannot connect on the network,
How? Right click on My Computer.
Select Computer Name
Click Change to change the name of the workgroup that is being use by other computer. Delete the old name if the same and retype.
Restart the computer and try to connect using network neighborhood.
Jul 07, 2010 | D-Link DSH 16 (DSH-16) Networking Hub
When will you use hub?
if you have more than one computer and you want to go online on all computers at the same time you can use Hub but it will slow down the internet speed upto an extent.
Feb 27, 2010 | Computers & Internet
Driver for QuickCam Communicate STX
The software and drivers for Logitech QuickCam can be found at the link below
http://www.logitech.com/index.cfm/435/352&hub=1&cl=us,en
just enter your operating system to be directed to your software.
Jan 06, 2010 | Logitech QuickCam Communicate STX Webcam
What does it mean if the link light is out on the surfboard v 5222 digital voice modem?
The link LED on the LAN card and/or on the hub/router is switched on then it indicates that the communication between the the computer and hub/router is established and therefore data can transfer between computers, hun/router, Internet etc.
If the link LED light is out then the fault could be a faulty LAN cable or faulty LAN card in the computer or a faulty hub/router.
Nov 15, 2009 | Motorola Computers & Internet
HOW TO CONNECT IT TI A COMPUTER?
When the computers are powered up and connected to the D-Link hub,
the computers that are connected to the hub will light up the various LEDs on the hub to indicate which port on the hub is active. Also that computer's network card Link LED light should be on to indicate it is connected to the hub.
If the hub's LED is off and the corresponding computer's network card Link LED is off then the network cable is faulty, or the network card is faulty (or the network card driver needs installing) or the port on the hub and/or hub is faulty.
To determine which item is faulty, swap network cables around, swap computers to different ports on the hub etc
Jul 29, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
D link DES 1048G Switch, is facing communication problem
u r saying after restarting of switch it is working fine.
  1. is ur switch is getting hit while it is hangup
  2. leds are starting blinking ??
if switch get hit u need to send it to service centre and replace card.
if switch is hanging while all LEDS are blinking this means one of the network calbe is getting short. u may need to search the faulty cable and restart the switch
May 09, 2009 | D-Link DES 1048G (DES-1048G) Networking...
Scanning Problems
Solution This issue can be caused by the way the USB chips in the product and the USB chips in the computer interact, or it could be caused by an old version of the HP software and driver. First, make sure that the most recent version of the HP software and driver is installed on the computer, and then try testing the USB devices and ports on the computer. If the product still does not scan correctly, a powered USB hub might help resolve the USB communication issue. Follow these steps to test the USB connection and see if a hub is necessary. Step one: Make sure that you have the most recent version of the HP software and driver The HP software CD that shipped with the product frequently does not contain the most recent version of the software and drivers. To make sure that the software is the most recent version, download and install the most recent version of the software from the HP Web site. The software and driver downloads available from the HP Web site include a Basic Driver option and a Full Feature Software and Driver option. The basic driver is sufficient to perform basic printing functions with the product. The Full Feature option installs extra software to allow full use of all features available with the product. The Full Feature option also allows custom installation. Follow these steps to download the software from the HP Web site and install it on the computer.
  1. Click here to go to the HP Software Download Page .
  2. In the Enter a product number text box, type the product model name (for example, HP Photosmart C3180), and then click Submit (c01425574.gif ) or press Enter .
  3. Under Product search results , select the product model name from the list that appears on the computer.
  4. Select the operating system that is installed on the computer. The Select Software and Drivers page appears.
  5. If the Automatically check to see if you have the latest software and drivers link appears at the top of the page, click the link and then follow the on-screen instructions to check the software and driver version and update the software if necessary. If the Automatically check to see if you have the latest software and drivers link does not appear at the top of the page, continue with step 6.
  6. In the Driver section, review the list of available driver downloads, and then click the appropriate package.
  7. Click Download Only and then follow the on-screen instructions to download the software.
  8. To install the software, double-click the icon for the downloaded file and then follow the on-screen instructions to complete the installation. CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 3 m (10 feet) long.If any firewall messages appear during installation, click Unblock or Accept or the installation fails.If the User Account Control screen opens, click Allow to continue.
Step two: Test the USB connection
  1. Disconnect all USB devices, such as printers, scanners, speakers, and cameras, from the computer except the mouse and keyboard.
  2. Connect the USB cord from the HP product to a USB port on the computer that is known to work correctly. Test the connectivity related functionality of the device (for instance: scan to file.)
  3. Print a self-test page from the product. NOTE: For information about how to print a self-test page, see the user guide for the product.
  4. Test the standalone functionality of the product by using the product control panel to scan a document or an image. NOTE: For information about how to use the product control panel to scan, see the user guide for the product.
  5. If the scan from the control panel works correctly, connect one USB device at a time to the computer and test the product by scanning from the control panel after each device is connected.
  6. If the product scans correctly from the control panel after every other USB device is connected, the USB connections are working, and you have resolved the issue. If the product does not scan correctly from the control panel or does not establish communication with the computer after a USB device is connected, the computer might not have enough power to run multiple USB devices. A powered USB hub might help establish or maintain communication between the computer and the product. Go to Step three: Use a USB hub.
Step three: Use a USB hub A powered USB hub might allow all the USB devices to receive enough power to run correctly and it might resolve USB communication issues between the product and the computer. Follow these guidelines when choosing and setting up a powered USB hub.
  • Make sure that the USB hub is a powered hub and the power adapter is included. Some powered hubs do not include the power adapter as a standard item.
  • When setting up the hub, it must be plugged into a power source.
  • Some hubs cannot handle more than four full-power USB devices, such as the HP product. To connect more than four full-power USB devices, use more than one powered USB hub. Most Windows computers can support a maximum of five USB hubs.
  • If there are multiple USB hubs connected to each other or if there are more than four USB devices connected to the hub, the issue might persist. Move the HP product to the hub that is directly connected to the computer USB port.
Workaround If these steps did not resolve the issue and purchasing a powered USB hub is not possible, the issue might be resolved by turning off the Preview option in the HP scanning software. NOTE: This workaround does not resolve problems scanning from the control panel. Follow these steps to turn off the Preview option.
  1. Click Start , click All Programs , click HP , and then click HP Solution Center . The HP Solution Center window appears.
  2. In HP Solution Center, click Settings and then select Button Settings .
  3. Clear the check box next to Show preview when scanning from the Scan Picture button and then click OK .
  4. Quit HP Solution Center and then try scanning again.
May 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Bought HP S20 New in box on Ebay......installed software......powered up and linked USB......message "communication with scanner lost" cannot rectify
I use an older USB Powered Hub between my computer and the S20 scanner, a Belkin I found at a garage sale for $2 works fine. It is only rated for USB 1.1. The S20 is a USB 1.1 device. My computer was "too fast" with its USB 2.0 ports and it looks like I needed to "slow it down". There is no way it will worked plugged directly into the computer, but plugged into the hub, and then the hub plugged into the computer, it is very reliable.
Windows XP had nothing to do with it, from what I can see. I had Windows XP on a previous computer with only USB 1.1, and ran into the problem when I got a computer with USB 2.0 ports.
Jan 03, 2009 | HP Photosmart s20 Film Scanner
Calculate network topology cost
Answers as follows
  1. $100 ({n(n-1)}/2)
  2. $50 (n links)
  3. 3 (number of pcs/2)
  4. 1 (in any hub topologyonly one pair would commm. at a time)
  5. Bus ( $40 n-1 links)
With Regards,
TPV
Jan 12, 2008 | Compaq NETELLIGENT 3024 24-PORT 10BASE-T...
D-Link DFE 2624 Networking Hub Logo
63 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
