Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
How do I replace drive belt - Hoover U6630-900 WindTunnel Bagless Upright Vacuum
  • 126 Answers
Turn the vacuum over,were u are looking that the bottom of it there is a plate that covers the brushes and pulley for the motor remove this plate should be three to four screws the plate will lifted from the back it has two hooks on the front,,after u have done this u take the brush roller out by pulling straight up on it notice how it comes out it should have hexagon ends on it it will side back in the same way,,now take the belt off clean off any debris if necessary put the new belt back on the motor pulley and roller brush, side roller brush back in(this might be a little hard scene u have the new belt on)and be sure that ends of the roller brush sets all the way down on the sides,then put back the plate start from the front putting the hooks on first on the front then replacing the screws, u shuold be good to go, Hope this was helpful
Posted on Apr 06, 2011
HOW TO REPLACE DRIVE BELTS?
It is not possible to tell you how to replace a belt on a machine you do not specify, there are hundreds of makes and models.
Aug 17, 2014 | Vacuums
My Oreck XL 21 stopped self perpelling, what so I need to replace or fix?
There is a small drive belt that turns the wheal that may need replacing open the drive belt compartment and replace like the brush belt. Turn the vacuum upside down to take out the screws it helps keep things in place.
Dec 26, 2012 | Oreck XL Ultra Bagged Upright Vacuum
How can I get to motor drive on g4 does it have a belt
The power drive has a geared belt on the end on the armature which operates the power drive. The power drive has been out since 1990, and I have yet to see a bad drive belt in 1000's of repairs. The drive unit itself will fail very infrequently, and need replacement. The belt can be accessed be removing the handle, switch plate, and upper motor shell. The power drive unit must be loosened and dropped down to remove the belt.
Dec 15, 2010 | Kirby G4 Bagged Upright Vacuum
When selecting the carpet cleaning mode, it appears the belt is slipping (due to the noise) over the drive pulley. How do you access the drive mechanism to replace belt or inspect drive pulley and belt...
On those units you must replace the clutch assy. you cant just replace the belt. there is also a special tool used to get the new belts on the brushbar. If you would like me to walk you through this repair let me know.
Feb 27, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Replace the belt on a upright vac
There is a very small wheel attached to the motors drive. Belt goes around the motor drive wheel and then around the drive roller assembly
Feb 22, 2010 | Kenmore 34612 Bagged Upright Vacuum
Belt drive not working. Won't turn beater brush.
You need to replace the belt. Here is the belt you need and the manual which has instructions:
Dyson DC07 Belt and Manual
Jan 09, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Dyson DC07 drive belt replacement
Hi.
The other end of the drive belt the part you cant see goes to a clutch.
The clutch unit has 2 belts one is clutch to motor the second is clutch to brush roller.
You obviously look after your machine because you say you have had no problems with belts or clutch for 5 years.
Both belts & clutch can be worked on but its alot to explain so look at this site for service manuals.
http://dysonmanuals.llc.nu/
Jun 01, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I replaced the agitator bar drive belt on a Hoover Model U6432-900 upright vacuum cleaner, but it just slips when the drive wheel is spinning. Is there an adjustment I need to make? I don't see any...
You probably should have replaced the flat belt(38528035) also. But the drive belt has a idler wheel(#13) to engage it, is it riding on the belt, if not if may have jammed to one side and able to spring up against the V belt. It could have broke also.
Mar 09, 2008 | Vacuums
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
67 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
