Question about HP Computers & Internet
I cannot get my ink cartridges in the printer, please let me know how to do this! Thanks Pat
  • Randy Villalobos
    Randy Villalobos May 11, 2010
    we need your printer model.
    Problem Solver:
  • 6 Answers
Same as randy`s answer dink
Posted on Aug 06, 2008
I have a hp desk jet 3520 it wont print it keeps saying intall setup cartridges but i have them installed correctly.
Are these the ink cartridges that came with the unit?
Are you sure they're in the correct positions?
Possible that one of the chips is defective. Try replacing with a new cartridge.
Jul 21, 2014 | HP Deskjet 3520 e-All-in-One -...
The printer has been sitting and never used. all hooked up and paper comes thru with nothing. thanks if u can help.
Hello hol0,
If the printer has not been used the ink cartridge may be dried/clogged. This happens when ink does not flow for long periods of time. The cartridge may be full of ink (therefore, not giving low ink level warnings) but unable to flow due to clogged pathways. Try a new ink cartridge and that should fix your problem!
Hope this helps!
Jul 01, 2011 | Canon PIXMA MP210 InkJet Printer
I just purshased a lexmart pro 705..How do you install the ink???please help
Replacing ink cartridges
Make sure you have a new ink cartridge or cartridges before you begin. You must install new cartridges immediately
after removing the old ones or the ink remaining in the printhead nozzles may dry out.
1 Turn on your printer.
2 Open the printer.
Note: The printhead moves to the cartridge installation position.
3 Press the release tab, and then remove the used ink cartridge or cartridges.
4 Install each ink cartridge. Use two hands to install the black cartridge.
Note: Install the new ink cartridges immediately after removing the protective cap to avoid exposing the ink to air.
5 Close the printer.
The setup guide is on theCD you received with the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | Lexmark Office Equipment & Supplies
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Thanks,
Pat
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
Printer flashes error "replace color cartridge"
Try unplugging the machine and removing all the ink cartridges.
Now plug the power back in. Wait a minute or two and then reinsert the ink cartridges.
If you get the same message, the machine's ink sensors are probably finished.
Thanks,
Pat
Nov 08, 2010 | HP PhotoSmart 1115 InkJet Printer
IT WON'T PRINT DO i NEED A USB CABLE IF SO WERE DO i PLUG IT INTO ON PRINTER? THANK YOU ALSO DO i NEED A BLACK INK CARTRIDGE?
Hello Grannie,
You will need a printer USB cable to connect the printer to your computer. These cables a standard for all printers and look something like thispatzky.jpg.
You should find a square like opening on the back of the printer to connect the cable.
As for the ink cartridges, I believe lexmark only requires either a color cartridge or a black cartridge to be installed. Use one of the two and the printer should work.
Thanks,
Pat
Nov 07, 2010 | Lexmark Z2300 InkJet Printer
I have mfc 440cn. Do I need to replace the drum?
The MFC-440CN does not have a drum.
The only consumables this printer has is ink cartridges.
These wil need to be changed when they are empty.
Thanks,
Pat
Apr 07, 2010 | Brother MultiFunction Center MFC-440CN...
It tells me the cartridges are empty, then when i open the lid it says no cartridge! its not been used for a few months, and i refill them with generic refills...any thoughts? tried the switch off and on -...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Make sure that your ink cartridges are full and that they are genuine brother inks; refills or generic ink cartridges are not guaranteed to work properly.
Thanks,
Pat
Mar 29, 2010 | Brother MFC-620CN All-In-One InkJet...
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Thank you,
Pat
Mar 28, 2010 | Office Equipment & Supplies
Canon pixma mb780- only prints red
Take then all out. shut the machine down pat attention and reinstall in the correct way check the manual
May 09, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
