Question about LG LRTN22320 Top Freezer Refrigerator
Background= My 4 year old unit is seldom used but is always plugged-in and powered. It is installed in a vacation house. Sometimes it takes weeks or days before it is opened. Breakdown - After a few days without opening, it was found to have stopped and all contents got spoiled. Repair - 1. Authorized LG technician was called and he replaced the capillary tubing. After few days observation, it was not cooling enough. 2. Same technician was called and he replaced the compressor. Cooling was sufficient but cooiing seems not as fast as before. Also our electric bill jumped up. Current reading seems to be normal and defrost timing cycle seems to be ok too. I know that compressors of refrigerators cut-in and out several times day as soon as desired temperatures are reached but I noticed that the compressor of this unit seems to be operating continuously. Questions- 1. What could be the reason for the increase in electric consumption? 2. Once repaired, will the unit be re-stored to original efficiency? 3. What can I do further?
4 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: LG LRFC22750ST fridge is 3 years old and the top
During the Automatic defrosting cycle there is a 60 Deg F thermostat on the evaporator that must cycle to terminate the defrost cycle and restart the compressor. If for some reason the defrost heating element is not coming on (failed / open / wire terminal problem) The the unit will just sit not operating until it reaches 60 F in the evaporator section of the freeser compartment. I suspect that you have an Automatic defrost heating element problem. Again that can be from a broken wire / terminal or the element itself has failed. It is possible that the 60 deg F thermostat itself is sticking and not cycling when the temp of the evaporator reaches 60F. It can also be caused by the temperature control that does not complete the circuit and start the unit when the fresh food section reaches cycling temp 34 - 37 deg F.
Your particular unit uses a thermistor and what is listed as a sensor to control the defrost and cycle temp circuits.
Parts list here:
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Refrigerator-Parts/Model-LRFC22750ST/3204/0161000/P0809090/00002?blt=06&prst=&shdMod=
Sensor is Item 903E
I am NOT telling to order anything thing. The only way to find out is to read out the components.
Thanks for choosing FixYa.
Kelly
This requires that the back of the freezer compartment be opened to troubleshoot and repair. Troubleshooting is done via resistance checks from the defrost control board or timer to the compressor. Usually blue wire from the control to the orange wire on the compressor then finding out which component has failed by reading resistance before and after each component.
The only way to find out is to use a meter.
Kelly
Posted on Sep 23, 2010
Testimonial: "Thanks Kelly =)"
jumptrout51
  • 3361 Answers
SOURCE: French 3 door LG refrig.. Not cooling but
You either have a defective start relay or a defective compressor.
If it is clicking every 45 seconds or so,you can try a new start relay.
Feel the compressor.
Is it hot to the touch?
Is the compressor fan motor running?
Posted on Apr 06, 2011
  • 142 Answers
SOURCE: LG Refrigerator GR2211GDC. Compressor was
Whoever replaced the compressor obviously left a leaking solder joint. That needs to be fixed, after which the unit needs to be recharged.
Posted on May 26, 2011
How do I unplug a drain if I do not have an air gap
Is it a plugged problem or is the drain solenoid maybe not working. Do you hear a click when it reaches drain cycle. If not the drain valve or wiring or possibly even the timer is defective. VERY seldom that a drain hose would plug up. Make sue the hose is not kinked also. You may have plugged house plumbing under the sink or etc also.
Sep 12, 2014 | Dishwashers
I have 2 Canon Power Shot 70 cameras (one was a gift) The oldest I have owned for approximately 4 years...the other one slightly less. About one year ago while on vacation, the camera refused to take...
Yes it is a design flaw, basically what happend is the image interpereter and preprocessor are shot.. The integrated method of the design leaves the irrepirable.. I dont use canon products except for printers and scanners when it comes to camera's i use Hp or Pioneer, Consumer support suggested a new camera cause they know where they messed up
Jul 14, 2008 | Canon Cameras
Unit exactly one year old. Was interruped by lightning strike last night. Afterwards air handler blowing, but not cooling? Turned unit of at temostat, waited a few minutes, turned back on and unit (both...
Marion, if there was a lightning strike and then a power surge when the power came back ON, I don't doubt what the servicemen had to say. The age of the unit plays no role in it, when something like this happens. Power surges can be killers to electrical appliances. That's why it always wise to turn the unit off during a power outage. Just ask anyone who was in Irene's path a couple of weeks ago. Power went out for days & weeks for some, when it came back ON, electrical appliances were damaged or ruined or started house fires.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Amana Heating & Cooling
Is the day of the week in the middle of dau or night or at the beginning it on the GE vacation timer?
Vacation timers turn lights on-and-off at random times.
Timer dial rotates clockwise. Notice small arrows on timer dial located below each day letter.
Each day starts at the letter.
When the time-now pointer is at W, then wednesday starts.
For example W is wednesday. And th is thursday. The hours that show between W and th are wednesday hours.
Open following image. The time now pointer is pointed at 4:00pm Wednesday.
The blue letters with white background are AM, and white letters with blue background are PM.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
To set current time, rotate dial clockwise until current time lines up with time-now pointer.
Time-now pointer is stationary.
Open following link to see how to set timers by experimenting with features.
http://waterheatertimer.org/How-to-set-timers.html
Add a comment for more free help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 19, 2011 | GE 50462 7Day Random Vacation Timer
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
Face of the timer doesn't indicate which numbers are a.m. and which are p.m., so how am I supposed to set the current time? There's an "8-4-12" that's not shaded and then an "8-4-12"...
You posted under Woods vacation timer:
See large image
This is a 7-day timer.
Days are printed on the dial.
Each day has night time with dark background and daytime in light background
If you want to set time for Monday at 12 noon, rotate dial clockwise until Monday 12 (in light background) line up with arrowhead located on inner dial.
After that, move switch to TIMER
Timer turns lights ON-and-OFF at random times throughout week
Jan 10, 2011 | Woods Indoor 7 Day Mechanical Vacation...
Rheem heat pump,have to keep pushing red reset button for fan
Either the fan motor is going out OR the compressor may need a boost of power from a quick start.
When the compressor gets old, sometimes it requires a little extra power to get it going.
Your unit should be under work warranty if they installed it.
Jan 06, 2010 | Heating & Cooling
Does not pump out water and does not spin
sounds like maybe sock or nylon clogging discharge?call repairman back out you should not be charged,cause its only been two weeks,i would ask him if he still has old discharge pump,be willing to bet it was ok! Alot of repairmen today are parts changers,instead of troubleshooters,they dont take time to get to root of problem,they just throw parts at customers expense!!!!(if repairmen gives you a line tell him you will contact states attorney general(he will have a certain amount of time to answer to state,allot of paperwork)you can report online)also you should call frigidaire they should be responsible for any maintenance of unit(warranty)-also run a inline water filter to unit-make sure your outlet is wired correctly(hardware store sells tester just plug in and it has lites that tell if wired correctly)-when you get solved find out how to properly store when not using(may be able to run something in it to properly coat internal parts) :)
Jul 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Vertical portion pixelats then forms solid vertical lines. Problem intermitent but persistant. The tv is 2 years old, if its the lcd panel is it worth repairing? I think I have the same problem with a...
Note
In some cases, there are minor defects in some parts of the screen. Points that do not light, points with
brightness different from that of the periphery, or points with color different from that of the periphery.
Some pixels will always be on or always off. Please note that this is not a malfunction. So what this says is that it's not the Plasma Cell problem, its more like a bad board inside. You will need more info like schematic and find out which area the bad part is in.
Jan 04, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
LG LRTN22320 Top Freezer Refrigerator Logo
37 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
