Question about Kitchen Appliances - Others
I have a Casera Mini Deep Fryer which I have used once and now it won't heat up. There is no light.
  • 3 Answers
SOURCE: GE 106789 Cool Touch Deep Fryer
called Rival,they have loads of MDP-1 power cords sets,just purchased mine today.(1800-323-9519).BTW,,When asking ,its listed as MPD-1 instead of MDP-1,(typo error).Its the same cord.
Posted on Jan 23, 2008
SOURCE: Deep Fryer Element Won't Heat Up
I have the same problem 4 months and it wont heat up again
Posted on Feb 08, 2008
  • 77 Answers
SOURCE: Deep fryer wont heat up
I have the exact same deep fryer and it was doing the same thing if you take out all of the oil and clean it realy good it should work again
Posted on Feb 19, 2008
SOURCE: Bravetti Deep Fryer Model F1053B Not getting Power anymore
Have a Bravetti Deep Fryer model F1053B, only had it 2 weeks, wires burnt through bottom of fryer and burnt a hole in my counter top. This deep fryer is ****
Posted on Jun 28, 2008
ginko
  • 19396 Answers
SOURCE: Maximatic Elite EDF-4080 Deep Fryer - Heating Element Replacement
Contact Maximatic and ask the replacement, use the contact form here.
Posted on Nov 30, 2008
How much oil do you use in a crofton mini deep fat fryer
I takes 1.5 litres of Sunflower/Vegetable Oil to fill this mini deep fat fryer
Feb 21, 2015 | Kitchen Appliances - Others
Light comes on, but it no longer heats up.
I have a similar model of DeLonghi fryer, and I have read that many customers have problems with their fryers not heating, after owning and using them regularly for some time. Mine gives an error message and stops heating, once in a while. The lights remain on, but it displays an error message on the temperature readout. I've found that detaching the magnetic safety cord and thoroughly cleaning both the cord and the connections on the back of the machine makes a big difference. Your mileage may vary.
Mar 04, 2011 | DeLonghi D14522DZ Deep Fryer
I have a ck20 hobart deep fryer that when plugged in and turned on, lights both lights,but does not heat.I checked both fuses with an ohm meter and they appear to be fine.Can you tell me what the...
The element will show infinite resistence if defective. Overload switch.....Do you mean High Limit T/Stat? Use your ohm meter across terminals- should read closed circuit...0 ohms. If not, push red reset button...if clicks once, is now reset and contactors will close and unit will heat. If always clicks, replace limit t/stat Like wise, check themostat--should click once for heat demand and check cicuit same as limit t/stat. May have wire burned off terminal connector at element.
Mar 30, 2009 | Hobart 1HF50D Deep Fryer
Light comes on but oil does not heat
check timer or power button,level oil.
Feb 05, 2009 | Presto 05442 CoolDaddy Deep Fryer
Lighting the fryer
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Jan 25, 2009 | Pitco Frialator SG14 Deep Fryer
Jan 11, 2008 | Black & Decker DF250 Cool Touch Deep Fryer
Kitchen Appliances - Others Logo
75 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
