Key StorageDevicePolicies does not exist - Computers & Internet
The disc is write-protected What is the solution
1. Go to run, type regedit and press enter.
2. Navigate to the path:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies
If the registry key StorageDevicePolicies does not exist, you will need to create it manually.
3. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
4. Double click the key WriteProtect in the right window and set the value to 0 in the Value Data Box and press OK button
5. Restart your computer and see if this help
if there is no important file, try to format
Click on Start.
Type diskmgmt.msc in Run.
In the disk management window, select the pen drive, right click on it and click on Format. Now choose the File System and Allocation Unit Size.
Click on OK.
Sep 11, 2012 | SanDisk SDCZ50008GB35 8GB Cruzer Blade...
My flash drive keeps saying it is write protected.
Three possible Solution to this problem are:-
1:) First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
2:)Use a software tool Neo2.9
3:)1. Open Registry Editor by typing regedit in Run dialog.
2. Navigate to the key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\
3. Find a sub key inside it named "StorageDevicePolicies". If it does not exist there then we need to make it. Right click on "Control" key -> New -> Key. Name it "StorageDevicePolicies" without quotes.
4. Now right click on this newly created key and then click New -> DWORD value and name it as "WriteProtect".
5. Modify this key and give it a value 0.
6. Click OK, and remember to restart the PC.
GOOD LUCK...........
Feb 06, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Its write protection its not working what is the solution
The problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Jan 11, 2011 | Transcend (589307) Media
Write protected
Jan 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a USB Flash Memory PMP(3820MB) But I Can not format because of write protected on it. How do I Remove of it? please,help me!
PLEASE CREATE A SYSTEM RESTORE POINT BEFORE PROCEEDING !!!
You'll need to tweak your Registry a bit:
1. Open Start Menu >> Run. Type "regedit" (without the quotes) and press Enter.
This will open the registry editor.
** If the registry key StorageDevicePolicies doesn't exist, you'll need to create it manually.
3. Double click the key WriteProtect in the right window, and set the value to 0 in the Value Data box. Press OK.
4. Restart your computer.
5. Try to format your USB flash drive.
(if you experience any problems after editing the Registry,
roll your system back to the restore point you created.)
Jan 04, 2011 | Computers & Internet
MY PENDRIVE HAVE ONE PROBLEM( COPY WRITE MUST BE PROTECTED ) PLEASE REMOVE THE WRITE PROTECTION
1. Click Start > Click Run, type regedit and press Enter, this will open the registry editor.
Download this batch file called add.bat, and double click after download the key will be automatically added to registry.
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. Check
In case you still find an issue, please let know me.
Oct 28, 2010 | Computers & Internet
Pan drive is write proction
From Start menu, point to Run, type in: regedit
If you are using Vista or Windows 7, just type in regedit in the search box when you click on the Start menu.
Navigate to the key:
Find a sub key inside that is named "StorageDevicePolicies". If it does not exist there then we need to make it. Right click on "Control" key -> New -> Key. Name it "StorageDevicePolicies" without quotes.
5
Double click this key to modify and give it a value 0. The value 1 in here means to enable it, while the value 0 is the opposite to disable it.
6
Click OK button to save and exit Registry Editor.
Thanks.
Have a great day.
Oct 11, 2010 | Computers & Internet
I am trying to put music on to a memory card that already has music on it but it is telling me to remove the write protection on the card. How do I do that please
Try this :
Oct 03, 2010 | Office Equipment & Supplies
How do I remove the write protected on my Lacie 500g external drive?
Steps to make your drive Write Protected Or Remove write protected:
3. Find a sub key inside it named “StorageDevicePolicies”. If it does not exist there then we need to make it. Right click on “Control” key -> New -> Key. Name it “StorageDevicePolicies” without quotes.
4. Now right click on this newly created key and then click New -> DWORD value and name it as “WriteProtect”.
5. Modify this key and give it a value 1.
Now no more data can be transferred to the drive but to start using the drive again just give the “WriteProtect” key a value of 0 instead of 1 and restart the PC.
Aug 12, 2010 | LaCie (301146U) 320 GB FireWire 400...
"storage device policies" key is missing from my registry...!!!
my mp3 player says that it is write protected when i plug it in ,.... so i was directed to change the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control \StorageDevicePolicies value from 1 to 0 .... when it looked it up i saw that inside the control folder the "storagedevicepolicies " is missing... my comp is normal and is not behaving abnormal..... plz help.... thanks in advance..
Mar 24, 2009 | iLO (2 GB) MP3 Player
Computers & Internet Logo
247 people viewed this question
David Payne
David Payne
