Question about Pentax *ist DS Digital Camera
Shutter release I just purchased this camera and while I was taking a photo indoors I pressed the upflash button and eversince then every single button I press on the camera (including the off switch) sets off the shutter release. In addition to this problem I can no longer see though the view finder unless I am pressing the shutter release button and then I can momentarily see through the viewfinder. I have noticed that if I press the shutter release button, it does not allow autofocus and it appears to be taking photos continuously but none on recorded in the play mode. Please help!
Take it back to the shop
Posted on Oct 11, 2008
All i want to know is if the canon a620 can be set to take a photo on its own without pressing the button to snap the photo....i want to take 'certain' photos of myself and no one to take...
No, you have to press the shutter release button to take the picture.
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. This sets the self-timer. Start the self-timer by pressing the shutter release button as usual.
Apr 06, 2011 | Canon PowerShot A620 Digital Camera
IT TAKES A LONG TIME TO TAKE A PHOTO FROM WHEN YOU PRESS THE BUTTON
This is a common situation with many compact point&shoot cameras. Larger and more expensive dSLRs have additional hardware that eliminates this "shutter lag".
You can eliminate much of the lag by anticipating the peak of the action. Press the shutter release button halfway to focus and meter, and hold it there until the moment, then press the shutter release button the rest of the way.
Feb 04, 2011 | Pentax Optio M30 Digital Camera
My Nikon Coolpix L3 takes a good few seconds to take a photo. By the time the camera takes a photo the moment is gone. I'm sure it wasnt always like this. Can you help?
This is a common situation with most compact point&shoot cameras. This "shutter lag" is because the camera has to do so much work when you press the shutter release button: focus on the subject, meter the light for proper exposure, and switch the electronics from viewing on the LCD to recording to memory. Larger (and more expensive) cameras have additional hardware to reduce this lag.
You can reduce the lag somewhat by anticipating the action. Press the shutter release button halfway to focus and meter. Keep it pressed halfway until the right moment, then press it the rest of the way to take the picture.
Jan 08, 2011 | Nikon COOLPIX L3 Digital Camera
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
Oct 31, 2010 | Nikon D40x Digital Camera
Nikon d90, blinking "Error"
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
Feb 18, 2010 | Nikon D90 Body Only Digital Camera
EOS 30D is slow to fire.
Are you sure you aren't in the delay setting in drive mode? This camera has 2 delay settings, one for 2 seconds between when you press the shutter and when it takes the photo, and one with 10 seconds delay - often used when you want to be in the photo (e.g. self-portrait or group photo).
If you aren't in the delay mode, then I need to know more about your settings. What shooting mode are you using? What type of photo are you trying to take (portrait, landscape, sports)? Are you shooting indoors, outdoors, bright sunlight, overcast, etc.?
Dec 30, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
What autofocus modes does the DiMAGE A200 employ?
AF single or AF continuous can be selected. In AF single mode, focus is calculated and set when the shutter-release button is pressed partway down. This mode is mainly useful for a stationary subject. In AF continuous mode, camera continues to focus on a moving subject even when the shutter-release button is pressed partway down. It is convenient to capture the moving subject. Full Time AF that continues focusing without pressing the shutter-release button can be used in both AF modes.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
The camera takes too long to take a photo. What should I do?
Press the shutter button halfway and hold it to set the focus, then press it the rest of the way down to take a photo. If you press the shutter button down all the way at once, it takes time to focus and set the exposure before the shutter releases. It may take longer than when pressing the shutter button in two steps.
Sep 12, 2005 | Epson PhotoPC L500V Digital Camera
Can't take picture with monitor off?
When the LCD display is "off" the focus mode is automatically switched to "Single AF" mode (since there is no way for the user to confirm that the proper subject is focused) and unless focus is locked the camera cannot fire. When the camera is in "Continuous AF" Focus mode the camera will take a picture whenever the shutter release button is pressed, wether or not the subject is in focus. You can take a photo with the monitor off, but the camera will have to lock focus before it can fire and will not respond as quickly as with the monitor on.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Pentax *ist DS Digital Camera Logo
91 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
