Question about Fendi FS 5011R Sunglasses
The left temple broke away, the plastic of the main frame holding the hinge broke. This is the second time. Is it a defect in the design? Can I get a refund? Any support documentation to take to my optomotrist?
  • 8,197 Answers
You can send your glasses to the link below to have repaired.
http://www.sunglassreplacementlenses.com/
Posted on Apr 11, 2011
Emerson microwave door latch
I have an Emerson MW8999RD that all of a sudden yesterday wouldn't latch. I don't think you have to, but I took the door off (three screws hold the case on which needs to be removed to get at the top hinge). Then I took off the inner plastic picture frame - pretty easy with a thin blade to move the fragile tabs. Then I removed the metal frame that has the little microwave blocking holes. This was the hardest part because the plastic retaining tabs are even more fragile and I broke one. Then I found the loose spring due to broken plastic hook as described above. I was able to make a new hook by simply looping a small zip tie where the old plastic hook tip broke off. Now works great!
Aug 22, 2013 | Microwave Ovens
Which material is used for sunglasses frames?
Sunglasses frames are made from metal or plastic. Metal frames, particularly expensive ones, are often made of mixtures of nickel and other metals such as silver. These frames have precisely engineered features, such as sculpted and gimbaled nose-pads, durable hinges with self-locking screws, and flexible temples.
Nov 07, 2010 | Clothing Accessories
Instructions for delta portable baby bassinet
It's easy. Hold the main skirt fabric and drop the pressboard support into the bottom with the feet/nubs down away from the inside. Now the metal frame drops in and next slide the hinged U supports outward. This raises the edges and gives height to the bassinet. The U supports either lock under a plastic clasp on the pressboard or sit into holes on the board. Now button down all the buttons around the interior. Set it back on the frame and snap the bassinet to frame snaps on. Add the hood and baby's new, clean bed is ready for a lullaby. Good luck and you should be able to download a PDF version of the instructions from the maker. Just go to their site and search.
May 09, 2010 | Delta Portable Baby Bassinet
Need left hinge/spring box
Precisionroller.com
their part number is H7914
Brother part number is LP2403001
Nov 18, 2009 | Brother DCP-8040 Copier
How does glove box come off to replace air cabin filter ?
First, take a good look at what you’re doing.
Look on the right side of open glove box and locate a plastic lever. You will see grooves on the end connected to the glove box. The grooved area is the spot to place the thumb in order to press this lever off the glove box when it comes time to do that.
Look up under the glove box. You will see two brass colored screws one on each side of the bottom of the glove box. These screws go up through two square plastic hinges that are attached to the glove box and into the the dash frame.
Okay, with the glove box closed remove the two brass colored screws, and put them aside so you won’t lose them..
Open the glove box and hold the glove box with your left hand and press on the plastic lever (grooved area) located on the right side of the glove box. This lever (the lever already mentioned above) is slotted and will pop off the glove box.
Put the glove box carefully aside.
Look straight in behind the glove box. You will see a rectangular black plastic cover approximately 1.5 inches wide by 8 inches long. On the right and left side are arrows pointing in. Press the arrows and pull out on the cover. This will slide out the tray that holds the filter. Remove old filter and insert the new one, flow arrows pointing down.
Retrieve glove box, hold in place, and attach plastic plastic lever to the right side of the glove box. The reverse of removal.
Next, the two plastic hinges located on the bottom of the glove box fit underneath the dash frame.
While holding the glove box in place (the glove box latch may hold glove box in place while installing screws) re-install the two screws through the plastic hinges into the frame and tighten.
Hope this helps you.
Oct 30, 2009 | 2004 Honda Accord
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Bell stroller left back wheel
I have same problem... I took the main bolt out that holds the plastic pieces to the metal frame, that holds the wheel assembly on that side. I pulled it off and found that the aluminum frame had actually ripped, broke a metal section off under the plastic area... Looks like the frame would have to be re-welded to function again... Take that area of your wheel apart, and see what is hiding beneath the plastic covering... Good Luck...
Sep 11, 2007 | Bell Sports Scout Jogger
Brother MFC-8440 Doc. Cover Open Error Message
I had the same problem, found your site and all of your suggestions. I ordered the same left hinge assembly from Vance Baldwin Electronics
Part #LP2403001 for $11.03, shipping from FL to OK was $9.23 UPS, so less than $20 and my MFC-8440 is working again! I did have difficulty placing the screws without a second pair of hands so have someone help you hold the lid. Make sure you removed the set ***** from at least the back of the left hinge assembly so that you can remove the "case" that holds the springs and sticky white parts. (Yes, I am a girl) :-). My husband will be so suprised when he gets home and sees that it works now because it was on his honey do list this weekend. Also, make sure that you replace the set screws and clean the scanner appropriately before use. I really like this site, it saved me a lot of money this time. Take Care!
Aug 22, 2007 | Brother MFC-8440 All-In-One Laser Printer
Fendi FS 5011R Sunglasses Logo
174 people viewed this question
Top Fendi Clothing Accessories Experts
Da Doc
ray gallant
Are you a Fendi Clothing Accessory Expert? Answer questions, earn points and help others
