I have moted into a house with this machine and there are no instructions on how to use it. I dont know what the buttons mean HELP
    Scholar:
  • 125 Answers
Since you have internet access this shouldn't be too difficult to solve. The first step is going to be to locate and write down the make and model number of your machine. The make may be Whirlpool, Maytag, Frigidaire, etc. That one should be in big letters usually on the control panel of the machine. The model on a top load machine should be located underneath the lid of the unit between the two hinges. Open the lid and look underneath the back part of the lid in the center. It can be hard to see, but there should be a sticker with model number and serial number printed on it. If it's a front load machine it should be just right inside the door (You're still looking for a sticker). Write down the model number and locate the manufacturer's website. The best way is probably to do an internet search for the make. Google Frigidaire for instance. After you locate the website you must navigate to the customer support section and look for links to "Owner's manuals" or "User's Guide." It should then ask you for your model number. Once you put in your model number you will most likely be given the option to download a PDF file of the manual. Open this with Adobe and print it out. It should contain all the info you need. Good luck.
Posted on Apr 06, 2011
How do i get pip on a ds27590 without a remote
The original remote will have the PIP button/buttons on it.
Nov 04, 2012 | Sanyo DS27590 TV
Tip
Syncing your Wii-mote to your Nintendo Wii
So you just bought a new Nintendo Wii Remote Controller but when you click the power button the four blue lights at the bottom just blink huh? Well that just means your Remote needs to be synchronized to your Wii.
Here are simple step by step instructions to do so.
1) Turn on your Nintendo Wii.
2) Open the door on the front of your Wii covering the SD card slot and the SYNC button.
3) Open the battery compartment on the back of your Wii-Remote Controller.
4) Press the red SYNC button on your Wii.
5) Press the little red SYNC button on your Wii-Mote.
6) Wait until a solid blue LED light comes on on one of the four lights at the bottom.
7) If it doesn't work the first time, try again.
Your Wii-Mote should now be synchronized.
on Dec 21, 2009 | Nintendo Wii Remote Controller
Gant get past language selection
This screen requires you to use motion controls, meaning you have to actually have the sensor bar set up properly, and then physically point the wii-mote at the buttons you want to select. You cannot use the arrows.
If you are having trouble getting the wii-mote to point, be sure that your sensor bar is in the correct position, that you are at least three feet away from the sensor, and the remote is one. If all three of those things apply, turn your system off, let it sit for a minute or two, then turn it on and try again.
If the problem persists, try syncing the remote via the remote's instructions.
Mar 08, 2011 | Nintendo Wii Console
My wii remote doesnt work properly. when playing bowling for instance instead of throwing the ball forward it throws it behind you, ( like what happens if you dont release the buttons correctly ) have...
To recalibrate you're Wii Mote put it on a flat table with it's button side on the table, leave it that way for 10sec.
Adjust de light sensitivety of the sensorbar in the Wii settings, in very light rooms the sensorbar will pick up the the light in stead of the Wii mote if settetup to sensitive.
Try also if all of this does'nt work new battery's for your Wii Mote other wise contact Nintendo.
Jul 28, 2010 | Nintendo Wii Console
Wii remotes dont do anything just get the four lights flashing?
You need to sync your Wii-motes to the system. Open the battery compartment on the backs of your remotes and the SD slot on the front of your Wii. Press the red SYNC button on the Wii console first and then on the Wii-motes. The remotes should syncronize to your system and work fine.
Dec 15, 2009 | Nintendo Wii Console
Controllers wont sync
If you have pressed the sync button on wii, then on the wii-mote, and it still didn't sync, try unplugging the Wii console for few minutes and try the process again.
There is another syncing mode, but you have to have at least one wii-mote connected to the wii. You press the home button and the click on the wii-mote on the screen. There will be a reconnect button. Press that and then press both the 1 and 2 buttons on the wii-mote[s] you want to connect. This is the ONE TIME ONLY connect mode, used when playin on a friends Wii. Once the Wii is powered off, the wii-mote wont be connected any longer and will still be the default wii-mote for your wii system [not on your friends]. Hope this helps.
May 10, 2009 | Nintendo Wii Console
Twilight Princess isn't recognizing the + or - on the Wii Mote
You need your disc cleaned - take it to a local Play N Trade store and they should be able to get it back to work correctly
Jan 19, 2009 | Nintendo The Legend of Zelda: The Twilight...
How to reprogram on my wii-mote??
Do you know where the SD Card slot is? If not, it's at the front just below the disc drive. Open the SD card slot entrance on the front, and take the back off the wii-mote. Turn the wii on, and at the health warning, hold the sync button on the wii-mote, and the one near the SD slot for 5 secconds. That should do it.
Oct 12, 2008 | Nintendo Wii Console
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
