Question about Lasko 48" Xtra Air Tower Fan with Air Ionizer
It is a Lasko Model 4820 and it stopped and just beeps when plugged in.
2 Suggested Answers
SOURCE: I have lasko fan sudenly it stoped oscillating can
I have the same issue, i determined the oscillating motor has a bearing failure. I need to find a replacement motor.
Posted on Jan 10, 2010
Manual for lasko model 4820
It is easy as just contact manufacture website
Feb 11, 2015 | Lasko Dryers
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
Whenn I turn my Lasko htr model # 5132 on it beeps twice n acts like there is no power. what can I do?
unplug the heater. clean the vents in the back using a vacuum cleaner hose attachment. wait 15 minute and plug the heater back in. This has worked for me.
Feb 14, 2010 | Lasko 5132 Ceramic Compact Heater
Won't turn on. It gave me a beep when I plugged
Have you cleaned the filter that's on the back? This has happened to me, and I just took the filter out and cleaned it, and it worked fine after.
Dec 27, 2009 | Lasko 5130 Ceramic Compact Heater
I have lasko fan sudenly it stoped oscillating can u help me with this ? Lasko 48" Xtra Air Tower Fan with Air Ionizer.Model 4820
Jul 17, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko heater beeps too LOUD
I was cleaning out my Lasko ceramic heater 6000, looking for instructions on how to do so, and came across your comment. After I opened it up and cleaned everything out (really easy, no instructions needed, it is all obvious) I started thinking about how much I hate that beep as well. So I decided as long as I had it opened to try to disable it.
Well, I could tell from plugging and unplugging that it was (unfortunately) mounted on the under side of the green circuit board. You will have to unscrew the circuit board completely (all wires still attached) and (carefully!) move it so you can flip it upside down to get to the other side. Note: there were 7 screws to remove and 1 was under the motor and really hard to get to. The motor looked WAY too complicated to remove so I got the screw started just a little with a precision screw driver and turned it the rest of the way with needle nose pliers.
Once the circuit board is off, the beeper is a little black circular thing (about 1/2 inch in diameter) with a little hole in the middle. It has a serial number on it and a "+" symbol. It looks like it is built in two pieces (upper and lower), so I tried to carefully remove the upper piece with needle nose pliers while leaving the lower piece connected to the circuit board. Well, the whole thing ripped out! I thought two things: 1) It will never beep again, and 2) I hope this didn't break a circuit causing the whole thing to fail.
Well, I put the circuit board back on ( I left off the one difficult screw, as 6 of 7 is more than sufficient to hold it on). Put the whole unit back together, and . . . . IT WORKS FINE!!!!!
Nov 30, 2008 | Lasko Ceramic Heater
Lasko 2535
Lasko 52" tower fan, model 2535, works fine but has the annoying loud 3 second beeeep when turned on/off, waking us up at night. Have been unable to get at the circuit board to investigate due to non-std screws (regular slot head but with a bump in middle of slot, so slot is filled in in middle of screw head, if you will)
Any thoughts on killing the beeeeping?
Mar 09, 2008 | Lasko 2535 Stand (Pedestal) Fan
Lasko 48" Xtra Air Tower Fan with Air Ionizer Logo
202 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
