Question about Iomega eGo 1TB USB 3.0 Portable - Ruby Red USB 2.0 Hard Drive
I can't connect iomega ego 1tb to my computer
    Scholar:
  • 92 Answers
Try removing all other connected usb devices. It may not be getting enough power.
Posted on Apr 06, 2011
Iomega eGo Helium 1TB has a damaged PCB. Local 1TB Casing do detects the HDD and its Drives. BUT asks for Formating the Drives. Which case can be purchased. how to recover the data. ?
It might be tricky, but you can remove the hdd from its casing, and install into a pc with compatible connections as a slave drive. Make sure to handle the drive carefully, and try to copy any data you want to another drive on the pc, then run chkdsk X: /f /r on the affected drive.
Another possible solution is to rightclick on My Computer, Manage, go to the drive mangement menu, and rightclick on the drive, and import it into your system so that windows can recognize it.
Mar 07, 2015 | Iomega Corp iomega eGo Helium 1TB 2.5"...
I have two Iomega 1TB 2.0 USB eGo harddrives with the encyption utility. I have the Windows 7 O/S. Initially, I plugged both harddrives (eGo) into my laptop, and created the password for each of the...
Iomega Utility are not Specific to the current device.
My iomega ego external hard disk was working properly but when i connected it today the encryption utility show that-Iomega Utility are not Specific to the current device and no any area shown to type password. My drive contains lots of valuable data. How can I acess into my drive. But the virtual drive is shown.
Aug 25, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I have iomega eGo portable hard drive with encryption... how do I create new folders on the drive to backup my data to?.....
click start all programs accessories open windows explorer right click on your Iomega then usually you would just right click an array of options will open up select new folder you can name the folder to anything you want as long as its not the same as the ones you already have on your computer
hope this helps
Apr 12, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
Well my problem is that my Iomega eGO usb 3.0, 1TB is not being recognized by my computer. when I connect the hard drive via usb 3.0, the computer doesn't recognizes it. I'm using the Conceptronic Pc...
you might have to uninstall the express card restart your computer then reinstall it also make sure its clean and securely seated and there is no dust built up or it might be trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Mar 23, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
How do i down load and view movies on my 1TB eGo Helium 2.0 portable hard drive?
You can't view them on it, it's just for storing the files. To store them you download the file to your pc, connect the drive to the pc and copy them to it in Computer.
Feb 21, 2011 | Iomega 1TB eGo Helium Portable USB 20 Hard...
How do i copy files into Iomega eGo 1TB? It is brand new but show no storage space left.
Well this method will destroy everything on it so make sure there's nothing on it. Go into computer, right click on your drive, click format, the options should be default unless you know what you're doing, this should restore all the space to usable space. If this doesn't work go to properties then tools and disc error checking, there might be a bad sector.
Nik
Jan 26, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
Is the Iomega 1TB eGo Helium Portable USB 20 Hard Drive compatible with the sony vaio laptop???
Yes, because it is a Plug-and-Play device, and because Windows supports Plug-and-Play.
Dec 23, 2010 | Iomega 1TB eGo Helium Portable USB 20 Hard...
Iomega eGo 1TB USB 3.0 Portable portable harddisk 500GB. while connected to PC show an error on desktop "insufficient power on USB hub port" . pls suggest
Few different things are possibilities.
1. Are you connecting the device via USB 3.0 to the USB 3.0 adapter on the computer? 2. Try switching out your USB 3.0 cable for a different one. 3. If you are using the USB 2.0 instead. Make sure you are using the USB Y cable for the device and not just a standard USB 2.0 straight cable. Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's into the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer as they will supply more power than the USB's on the front of the computer.
Dec 20, 2010 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
Iomega eGo 1TB USB 3.0 Portable - Ruby Red USB 2.0 Hard Drive Logo
511 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
