Question about Fusion Car Audio & Video
I have a FCD-135MP3 Headunit and it cut out on me when i was driving,and now it doesnt turn on at all...when i take the face plate off there is a small red light on,what is the problem?
  • 323 Answers
SOURCE: power problems
Try brushing off the contact where the face plate goes on, may have something stopping it from working right
Posted on Apr 20, 2008
  • 2318 Answers
SOURCE: face plate is black
The 12 volts lights that illuminate the face plate are burnt inside and should be replace. It's a common failure on any face plate.
Posted on May 04, 2008
tech48
  • 624 Answers
SOURCE: power to stereo none to unit
There is a ribbon cable that goes from the display to the main board of the radio that may be bad, if you have everything connected properly and all you get is the red led, this is a possibility. No way for anybody to know if you have it wired wrong if they can not look at it themself.
The red wire is for power when the key is on, the yellow wire should get power all the time, the black wire is ground.
If you have those correct, the radio should at least turn on. If you have these right, you may need a new ribbon cable. The connector that interfaces with the detachable face must also be taken off the old ribbon cable and put on the new one, or get a new connector and just replace it. The ribbon cable does not come with that connector. It is soldered on the ribbon cable, so if you are not very good with a soldering iron, you should have a service center do it for you.
Let me know if you want the part number for the ribbon cable and/or connector, I can get those for you.
I can not guarantee that the ribbon cable is the problem, or that it is the only problem, but it is the most likely problem with that model number of Kenwood. I have repaired many of them, so I have a good idea what causes most of the problems, but I have seen times when the usual suspect is not the problem and something else like the LCD in the face is bad, or the IC that controls the display is bad. Even a voltage regulator on the main board of the radio can be at fault as well. There are probably about 10 different things that can cause that one problem, having an experienced technician is always the best way to determan the problem with certainty.
Let me know if I can be any more help for you.
Dave
Posted on Jul 25, 2008
reynosaelect
  • 165 Answers
SOURCE: my dual xdm6820 doesnt turn on and theres a red binking light
Probably you are mising 1 voltage,check this you need to have 2 voltages ok,1 voltage has to be present on the yellow wire(constant voltage,means all the time,ok) and the second voltage on the red wire (this voltage has to be switched wiht the ignition key)check this and try to fix the problem,probably there is a fuse blown,you can use a tester light to check the 2 voltages.or if you dont want to do this just conect the yellow and red wires together and the unit has to turn on.
Posted on Mar 25, 2009
  • 61 Answers
SOURCE: I have one red light
Often this is not a sign of the red ring of death, so I believe you are in luck. Try to make suree all of your power cords are connected, also unplug them and plug them back in. Also try to remove your hard drive and put it back in. Hope this helps.
Posted on Mar 08, 2011
Bosch HMT9656GB Plate not turning
THE TURNTABLE MOTOR HAS FAILED its easy to fix and doesnt involve going near high voltages remove microwave and flip it onto its roof a metal panel at the bottom covers it up if its never been removed before you will need to cut out strips holding plate in place. this reveals motor held in with 2 screws replace motor a cheap, part reverse fitting it should now work dont forget to fit drive dog and turntable glass before testing.
Nov 13, 2016 | Bosch HMT9656GB Microwave Oven
I have a 99 tahoe and my heater is always on. I can not turn it off the A/C doesnt turn on. I had recently change the headunit.
wires to A/C commutter not correctly connected or A/C commuter broken. Replace it with the old one, on the old headunit
Apr 30, 2013 | Cars & Trucks
Can't Open FCD File
The FCD file extension is associated with Virtual CDROM. The .fcd files contain uncompressed backup image file format.You need to download an application that can open this type of file extension.
May 21, 2011 | IMSI CD Copier Gamers Edition 1.0 Full...
JVC KD-AVX1. The head unit will not "turn on" when the power button is pushed. The display just stays off. The face lights up when you press the eject button and opens up and you are able to feed...
is this a headunit you have just installed? if not then I am not sure, but if it is, try swapping the red and yellow wires over. One should have permanent live, the other should be switchable. (unless you want the headunit to stay on when the ignition is off, in which case put them both to a permenant live feed.)
Hope this helps.
May 09, 2011 | JVC KD-AVX1 Car DVD Player
Model FCD-123 Frigidaire malfunction
2 possible issues .evaporator fan motor is not working.you should be able to hear it in freezer.auto defrost is not working and vents are clogged with ice.look for ice/frost buildup on freezer wall///floor
Jun 25, 2009 | Refrigerators
Alpine CDA-9830 doesnt want to work
the cda 9830 and 9831 are known to have issues with the face plate connection that cause all kinds of issues. remove the face plate and clean the contacts on the face plate and the unit.
Feb 07, 2009 | Alpine CDA-9830 CD Player
No Display without pressing on the front
Absolutly "could" be the problem. Try using a q-tip with rubbing alcohol on it and GENTLY clean all contacts. Replace the face and see if tere is an improvement.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 24, 2009 | JVC KD-AVX33 Car Video Player
Hi, the motorized front of my Kenwood KDC-9027 is playing up. It stops the headunit turning on, when i can get it on the front moves and the unit is turned back off no matter what i press. The front feels...
maybe the flexible ribbon cable between the face plate and the unit itself is broken and needs to be replaced. check partstore.com for part if you can do the repair.
Aug 25, 2008 | Kenwood Car Audio & Video
Daewoo Cd player
The car security is not connected to a head unit. It probably has a small blinking red light on it which blinks when you remove the faceplate and switch the ignition off. This is just an indicator which lets people see that the face plate is removed.
You can replace the headunit with any brand/model you want. It would be cheaper than buying a replacement faceplate.
Aug 03, 2008 | JVC KD-S5050 CD Player
Faceplate will not open
Perhaps something is not installed correctly physically. Sometimes if something is a little twisted the way the unit is installed it will keep it from opening properly. Try moving the unit slightly and see if that helps.
Mar 15, 2008 | Sony CDX-M8800 CD Player
Car Audio & Video Logo
99 people viewed this question
Top Fusion Car Audio & Video Experts
Brandon Berry
Brandon Berry
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
