Posted on Apr 06, 2011
Cant detect my on my Pc Kingcom KM183.. Cant reformat it also.. What i have to do.. Is it dead?
1helpful
Nokia 6300 cannot be detected by my computer when
The PC seems to be OK. The phone switches off and hence can not be detected. You cant detect a dead device. Try a different battery. Or try using the charger while connectiong. If it does not go off then the battery is at fault. Change it. If nothig is detected faulty, then uninstall PCSuite . Restart the PC and re-install PCSuite without connecting the phone. When you connect the phone afterinstalling the SW, he phone will be detected immediately.
1helpful
MY PSP doesnt work whenever the SONY memory stick pro duo 4gb was inserted in it. Meaning there's is no display. Although the power is on and the LED Read indicator is on. and I cant turn the power off....
memory card is broken. you can use it again if will be reformatted but it will go back to the same problem again. best solution is replace it.
in reformatting try to reformat in digital cameras.
No HDD Found
First boot to the system setup and see if the Hard Disk Drive is detected in the BIOS. If it is not detected, then the HDD has most likely failed and will need replacement.
If not detected in the bios, open the chassis and reseat the Data and power cables to the HDD
2answers
Hard drive can't format
This is happening cause your rams are bad (not dead yet just leaking data) you need to have them replaced. You can take it out and take it with you to a store and purchase new ones. The rams are located on the main board and held in place by 2 plastic clips in an upright position, Its about 1 and 1/2 inches hight by about 4 inches long with a bunch of IC's tp the sides of it. Remove it by pulling the clips apart. To install just line it up and push down, it will snap into place.
I cant re format the acer4620series
hi!!!
maybe the hardisk has defect or damaged
try to borrow some hardisk from your friends
or buy new one and then reformat!!!!
Cant reformat
check the status of your hard disk on the bios of your laptop is it detecting or not, if its not then you have to replace the hard disk
 Grubhead
Grubhead
SmartAviator
SmartAviator
