Question about Black & Decker Blenders
My blender stopped blending and an on sign is flashing how do I restart my blender
Mine also stops and I just let it sit a few min and it gos a gane
Posted on Apr 06, 2011
After blending cake batter the blender became hot and it's not working what shall I do
You have burnt up the machine. It will no longer function and would be unsafe to try further. Replace it.
Jun 03, 2017 | Philips HR1350 SingleSpeed Handheld...
Looking for black and decker 550w 5 speed blender owners manuel
Try Googling (Black & Decker)(550w)(manual) without parens.
Jun 22, 2017 | Blenders
Waring blender shoots food out the top
Are you blending something hot? When you blend a hot item the steam that is released will increase the pressure in the headspace above the contents in the blender. The lid will eventually blow off to release the pressure.
To avoid this problem begin blending with no more that one cup of ingredients. Before turning the blender on, remove the center lid insert to allow venting of steam. Blend on low speed. As you blend you can add another 1 1/2 cups of additional liquid through the opening in the lid.
Trust this method will resolve your problem.
Oct 22, 2011 | Waring 6000CG 60th Anniversary Blender
Westinghouse inteliblender
Mine developed the same problem except it stopped blending while I was using it. Being an electrician I opened mine up and put a meter on the motor windings and found that the windings were open. So basically the motor is shot...unless you can find a part number for motor replacement or if your's is still under a warranty...it might just be easier to buy a new blender.
Sep 27, 2008 | Westinghouse 0101 IntelliBLEND¿ Work...
KITCHENAIDE BLENDER
sounds like you engage gogs under you canister are slipping or wore out lift up your canister to check them. not sure if your particular model has set screws in them or not look and see might be it hope this helps
Sep 01, 2008 | KitchenAid KSB5 Professional Stainless...
Motor works and then gets sluggish and slow
WELL, WHEN YOU UNPLUUGED THE BLENDER, AND RESTARTED IT - DID IT WORK. iF IT DID THEN IT MEANS THAT IT HAPPENED MIGHT BECAUSE YOU HAVE NOT BEEN USINGTHE BLENDER OFTEN.
bUT IF ITIT MAKES THE SOUNG AFAIN THAT THE MOTO OR WHERE THE CORD IS- SOME WATER MUST HAVE GONE INSIDE. IT IS BEETER OF YOU TO CHANGE THE BLENDER BECAUSE IT IS ALWAYS WRITTEN IN THE HANDBOOK THAT IF IT MAKES ANY KIND OF AEEFUL SOUND OTHER THAN THE NORMAL SOUND- STOP USING IT IMMEDIATLY.
Feb 23, 2008 | KitchenAid KSB5 Professional Stainless...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
May 17, 2007 | Waring PBB 25 Professional Work Top...
Blenders Logo
160 people viewed this question
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
