Question about Bosch Washing Machines
BOSCH WFR2460UC Washer displays an error message"unsuccesful update" unplugging it did not solve the problem
  • 4,323 Answers
Hi
First unplug it for 15-30minutes then plug it back and if the issue returns remove the front door seal from the front and clean the lock. If that won't solve this then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 06, 2011
I have a Bosch Axxis+ wfr2460uc. And as you can see from the picture, my display doesn't work at all. What do I do?
Front display board has failed or has a bad connection. With the machine unplugged remove the top of the machine and check that the ribbon cable and any connectors to the display board are inserted correctly.
Mar 07, 2015 | Bosch Washing Machines
Bosch 500 series washer control lights out
Suggestion: Try unplugging the washer for 30 minutes.
Apr 03, 2013 | Bosch Washing Machines
Hi I keep getting an error message "F27" on my
F27 OVERFLOW CONDITION
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Aug 31, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer Axxis+ gives following error message: "Pump blocked?" After manually draining the water it will work properly for half a dozen washloads, then the error message shows up again.
Have you tried cleaning the filter next to the drainage pipe? (Lower left near Door).
The compartment is opened by turning it anti-clockwise and pulling it out (Be wary of water coming out!).
Most likely a small obstruction (Coin, Rocks, Toothpick... and in past experiences a "thong") might be blocking your impeller.
Hope this helps, if it doesn't let me know and I'd get technical ;-)
Kind Regards
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Apr 03, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
E:27 error code. Wet laundry is locked inside the washer. How can I get the door open manually? I've already unplugged the machine and waited and tried resetting everything.
E:27 message means that the door locking mechanism has malfunctioned and/or is overheating. Unplug the machine for 30 minutes and try again. If that doesn't solve the problem you need to call the service.
Mar 05, 2011 | Bosch WFVC5400UC Washer
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Oct 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Error message: water tap closed .
check water inlet valve clean of rubbish from water inlet hose
otherwise water inlet valve maybe faulty
Dec 08, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
