Hi I have a Blanco front loader washing machine BFWM 7. all the lights come on and it will let me choose a wash program. but it will not start.
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
davess26
  • 7 Answers
SOURCE: error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Posted on Oct 26, 2008
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
SOURCE: washing machine stops and flashes 4E
1. WATER SUPPLY ERROR – Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Posted on Feb 23, 2010
Whatever the cycle you choose, the door open light turns on, even though the door locks when you start the cycle
I take it that it is a front loader, what make and model machine do you have?
regards
Graeme
Apr 20, 2008 | Washing Machines
Hi there, I have an LG WD-8013F font loader washing machine that made a loud pop with a burning smell when I tried to run a wash program. I turned it off, and after a while tried the wash program...
semakan
  • memeriksa
  • menyemak
  • ')" onmouseout="ht(this)">check
    capasitor dalam tenaga
  • dalam kekuatan
  • ')" onmouseout="ht(this)">in power
    memasuki
  • masuk
  • memasuk
  • ')" onmouseout="ht(this)">enter
    that duduk di dalam')" onmouseout="ht(this)">staying inside.
    Nov 20, 2010 | Washing Machines
    Front loader AWM 6100 - door open light flashes and won't wash
    I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
    Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
    Diesel smell in washing machine
    I recommend to take vinegar 100ml and keep the temperature of 65 degree and start the normal program most of your problem will be solved after doing this
    Jan 08, 2010 | LG WM-1832C Front Load Washer
    Which is better a top loader or front loader washing machine?
    Front Loading Washing Machine: Fully automatic.
    1. Better washing than toploading as technologically proofed.
    2. No extra effort except putting cloths and detergent inside.
    3. No need to observe in between while washing. Start and forgot. You can go market and come back.
    4. No issue if electricity or water went out during washing.
    4. Take more water compare to toploading semi-automatic.
    5. You can not open it once it started.
    Top Loading Washing Machine: Semi
    1. Save water and detergent.
    2. Need extra effort to put the cloth from one box to another.
    Oct 10, 2009 | Washing Machines
    Door not locking and program reverting straight to end
    initially i would replaced the door interlock then if no result the control boart could be faulty.
    Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
    Error code 7
    Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
    Water usage per cylce
    water usage is about right. top loaders use far more and so does hand washing
    only way there would be excessive water usage is if machine were overfilling
    Aug 13, 2008 | Washing Machines
    Washing Machines Logo
    160 people viewed this question
    Top Washing Machines Experts
