Question about Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model
Hi I have a 1989 LT 1000Craftsman 21hp 42inch cut with a Peerless Transaxle Model 2000./ Model number 917.273522 It will not move, checked the oil and there is none in the Pump just enough to show on the end of a rod i put in the check hole and the axle is allso low . The pump dose not make any noise as if it was going bad but I don't know much 80w90w to add. for 1989 is is in GREAT SHAPE just sat after the guy broke the Blade on a BFR he just left in and got a new one
    President:
  • 3,074 Answers
Is the drive belt off?
Posted on Apr 06, 2011
How do I install seal in the transaxle?
Require splitting the case if your trying to replace axle seals. Case is sealed with Permatex Ultra Grey sealant
Oct 16, 2014 | Craftsman Garden
Need free owners manual for a 6 speed craftsman Lt 20000 17.5 HP riding mower
You normally download the Craftsman manuals @
http://www.searspartsdirect.com/
You will the model number from the serial number decal under the seat area. This number usually starts with 917.
Aug 05, 2014 | Craftsman Garden
Peerless tecumseh transmission model mst-206-545c will not drive in gear
FYI I have a Craftsman LT1000 18HP twin opposed Briggs with a Peerless transaxle 206-545c 6 speed manual trans (not the Hydrostatic). I was given this Lawn tractor by a friend who took real good care of it. runs starts great but it started binding in 3rd gear and was very hard to get it out.of gear so by pushing the cluch/brake in and out manytimes and forcing forward into 4,5,6 gears I was able to get it out of 3rd.
Iam a mechanic and have over 30 years experience.so I decided to research the Peerless 206-545c transmission I found some great info online and helpful repair vids on youtube. I decided to post here to try and help people that are having the same issue with this trans. after I got the tractor in the garage I noticed the left rear wheel was wet on the inside with gear oil.so I decided to do a rebuild.after learning about this transmission.I went to sears parts direct.com and put in my craftsman mower model number and it came up with a exploded view of the tecumseh\peerless 206-545c. on the diagram. I found the 2 transaxle seals needed item# 157 and for like 15 bucks ordered them. you can order all the seals if you choose.
I realized that there is a fill PLUG ONLY and no drain plug on the bottom of transmission.you must take this transmission out of the tractor and lay it upside down in a oil catch pan and drain the fluid out. you must open the transmission all the way to replace the transaxle seals.Im told that most lawn tractors of today have disposable transmissions.another words they dont want you to fix them youreself they want you to bring it in so they can charge you to diagnose it and say yep you need a new transmission. lol thats why no drain plug.so if youre not a mechanic you gonna be payin boy..
I did find alot of BAD info in doing research on this transmission online ie: people posted wrong info saying that you just have to loosen all bolts on the trans case and you can put new seals in... VERY WRONG and the other wrong info was the amount of gear oil. the correct amount of 80w90w is 32oz 2/3 full from top(use a dowl or straw to measure. I use LUCAS high Performance. gear oil. I included a Tecumseh/Peerless link for you to check out. http://www.smallenginesuppliers.com/html/engine- specs/tecumseh/Tecumseh_Transaxle_Service_Information.pdf scroll down to MST 200 series trans find the 206 545c documentation and it tells you every thing you need to know about the 206-545c ie 90/100 inch pounds when torqing bolts on case. shifting adjustment (ball hex screw adjustment) 1 full turn after flush with housing.etc. I was able to save this transmission I opened it up and cleaned every gear by hand with Seafoam trans cleaner and put it all back together using permatex (GEAR OIL GASKET MAKER) and waa laa it shifts amazing and no more leaking from axle seal. I get no benefit from posting this just want other people to have the correct info and for around 40 bucks you can recondition this trans.if you open it up and find broken gear or gears go to ebay or sears and get parts which ever fits your buget.it took about 6 hours total to de install transmission and clean gears and put new seals and re install back into the tractor. just to give you a time frame. if you dont have time to rebuild it go to ebay there are used complete transmissions there but I would rather know what I have by doing it myself than buying used that may have the same issue and cost ya 200 bucks.
god speed bruthas
Aug 12, 2013 | Garden
How do I add oil to my sears garden tractors transaxle model no. 917.273320
I'am not sure about this model. Craftsman,usually services the Transaxle at the factory. Requiring no further servicing,unless you have a leak developing,then an overhaul of the transaxle has to be made.I would get a professional in a mower shop,to make this repair. Or Sears does this sort of work. I have seen this Transaxle,(A Peerless Transaxle),torn down for repairs. There is more small parts to this transaxle,then anyone other than a Sears Tech or someone trained to do this. Its more work,than a weekend doer can possible do. Hope this is answers your question,Brad Locke DTD. 12/03/15
Aug 06, 2013 | Sears Garden
I need a diagram for a peerless transaxle 855 Series
The Peerless brand is going through some changes. Here is the current info on the company.
http://www.peerlessgear.com/files/Peerless/splashimage_full3.jpg
Feb 15, 2011 | Garden
Tryng to id hydraulic pump on Bowlens G152 tractor. I have part number GPLI-16L010 but can't verify that its a Hyd pump.
if its a hydrostatic tractor it most likely has a techumseh peerless sealed transaxle. with the model and serial number your local dealer can tell you excactly what it is. dont go to homedepot or lowes find a local repair dealer is the best.
Feb 27, 2010 | Mtd 22" Yard Machine Push Mower
I have a Troy-bilt chipper/vac 47279 with a peerless transaxle Model # 9000-001. The recoil cup 1901304 is broken where can I get a replacment part.
check with you local service center that handles tecumseh parts. I can get it thy should be Abel too. your new number is 36221
Oct 17, 2009 | Troy-Bilt Chipper Shredder
Peerless Transaxle #206-545c locked up in 3rd gear, wheels won't
Sounds like your going to have to open up the tranny....
Sep 05, 2009 | Craftsman Garden
Change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Jul 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 21 hp 42 in. Deck Yard Tractor - CA Model Logo
198 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
