Question about HP Pavilion dv9000 Motherboard
My hp dv9000 keeps turning on and off, and if it does turn on theres just a black screen
    Sergeant:
    Champion:
  • 217 Answers
Unfortunately your GPU is bad due to over heating. Common problem with this model. you will need a new motherboard. If you replace it yourself keep this in mind. Replace the thermal pad with a copper shim and thermal paste, take the fan apart and clean it (probably full of dust and lint right now), change the bios setting to fan always running on AC, and always keep an eye on how warm or hot it is getting in the future.
Posted on Apr 06, 2011
  • HP Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Hp pavillion dv9000 lcd screen changes colour when moved
The inverter is to change the volts from the laptop to the Backlight. This wont have anything to do with it.
Im more than certian it will be the LCD cable. Proberly loose or torn at where the lid closes.
Hope this helps.
James
Feb 23, 2010 | HP Computers & Internet
Hi my HP pavilion dv9000 entertainment notebook's screen hasn't been turning on, what can i do to fix it?
hello sir,
this is a very common prbl in laptops . u not specify the prbl how n whn it occur, may b ur screen is damaged..if there is a break in screen thn the liquid in screen is flow n spread in screen the only solution is tht u change ur lcd display screen ...or may b ur belt (which is connected through the base is cut ) so there is a prbl arise in disply.
its better u can show it to any computer center near to u
Jan 26, 2010 | HP Pavilion dv9000 Motherboard
My hp pavillion dv9000 turns on but the screen stays black like it isnt getting any power to it
Connect your laptop up to an external monitor. If you get a picture on the external monitor then you know that your Chip is fine. At that point You will need to replace the screen.
Dec 23, 2009 | HP Computers & Internet
My hp pavilion dv9000 17 power on but see black screen
If your 9000 is under two years old, you should contact HP customer care and have unit serviced under warranty.
HP has had allot of problems with the 6000 and 9000 units and in response has offered an additional year from date of purchase.
Its worth a shut. Doesn't cost a dime.
Hope this information has helped you.
Oct 11, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000 Entertainment PC shows a black screen and nothing else when it is turned on...warranty expired in March 09. HP said not under warranty anymore and to take it to get serviced.
Try and hook it up to an external monitor by using a vga cable. If there is a problem with the main display, the laptop will drive an external automatically. I have to tell you though that these laptops are notorious for burning out the video processors in them. If that happens to be the case, you will need a new motherboard. The one good thing about that is that there are instances where the motherboard from a dv6000 and the dv9000 can be interchangeble depending on the model. If you do get a picture on the external display then you may have just lost the screen and they can be changed out by just taking the bezel off the screen and disconnecting screws and cables. Let us know
Sep 14, 2009 | Computers & Internet
Hp dv9000 switches on to show coloured lines on screen.
Hello
My first guess is that the screen circuitry has gone bad - although fixable. Use an external monitor to verify this. If the external monitor is fine then the screen circuitry is bad, if the external screen shows the same problem then the video chip or associated circuitry has gone bad. My company fixes these all the time.
Jul 28, 2009 | HP L1702 17" LCD Monitor
My HP Pavilion DV9000 turns on, but hard drive does not fire.
This is most likely the beginning stages of a video failure which is a known problem with DV9000 notebooks that have the NVIDIA GeForce 7600 Go Video Adapter. HP has issued a Limited Warranty Service Enhancement and your computer may qualify for free repair. Check out the following link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&dlc=en&cc=us&lang=en&os=228&product=3224049
Jun 21, 2009 | HP Pavilion dv9000z Notebook
When i start up my hp dv9000 the screen is black
There might be a chance you have turned the display off ... hold down the function key and then press F3 key to see if you have it set to projector look for the screen on the f keys
Sep 23, 2008 | Computers & Internet
HP Pavilion dv9000 Motherboard Logo
522 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
