Question about Garden
I have a swisher trim-n-mow the cable lets you start the engine broke need to replace it can you help me.
SOURCE: My swisher pull behind was working fine and I was
take the cover off above the ignition switch ckeck 4 loose wires if nothing is found wrong jump it at the selinoid if it starts go to the nearest perts store and buy a selinoid for an ole ford truck transfer wire exact and it should wrk fine
Posted on May 07, 2009
  • 4 Answers
SOURCE: cable streched on swisher trailmower
Pull the belt cover off on the side of the engage lever and you will see that it is not a wire cable that engages the idler pulley. It's a rod connected to a long spring. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Further, there is a return spring to pull the idler pulley away from the drive belt when you disengage the blades. Check all the connections for the springs and see that the engage lever is mounted tightly. Also check the idler pulley itself.
Posted on Jun 26, 2009
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
  • 420 Answers
SOURCE: Having trouble getting my swisher Trim-Max to
Check the fuel lines, you may have an air leak that requires new lines and a new filter.
Posted on Jun 04, 2010
  • 4 Answers
SOURCE: About my Swisher Z-Max ZT2660B...I was mowing, and
I would check the connections to the engage belt button then check the electric clutch connections
Posted on Sep 22, 2010
Engine runs on my swisher 2560 but will not move, stopped while mowing
Drive belt may have broken or idler pulley could have malfunctioned or drive belt could have just came off alignment.
Sep 10, 2017 | Swisher Garden
Swisher xzt 60.. while mowing grass pushing the arms forward the blades slow way down.. how can i fix this issue? I just put new deck and engine belts on..
Swisher is proprietary in the service arena for information. The most common cause of the issue that you are describing is belt slippage. This could be due to oversize belt length. improper tension, loose pulleys etc. Also when you look at an area that you have mowed after one day, if the tips of the grass are yellow, the blade is not sharp enough.
Jun 21, 2014 | Garden
I need the carburator bolt sizes for a swisher trim and mow 650 series model st65022q
you can best find this from the manual or the manufacturers website
Sep 08, 2013 | Briggs & Stratton Garden
Broke engine to deck belt after only 33 hours of mowing. Swisher needs to resolve this problem. Will they stand behind their products?
I also had the same problem, belts kept breaking after a short period of time, and the problem turned out to be the four bolts holding the engine to the frame loosened to the point the engine was tilting and letting the belt slip. Once new bolts with lock washers were installed, all has been good.
Sep 19, 2010 | Swisher Zt2350 Zero Turn Radius Tractor
May 03, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Garden Logo
150 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
