Question about 3Com Computers & Internet
Dear Sir / Madam Could you help me about 3com switch 4500, me using port 1/0/26 but this port always alert PTVL/5/WARNING:- 1 -the linke partner of Ethernet 1/0/26 may be bad, sending lots of error packets !. I think you will be reply the answer to me as soon as thanks.
  • 35 Answers
SOURCE: 3com 3300 TM - all Ethernet port not working, power led flashing
A blinking power LED means that the switch is either downloading software, or is initializing which also includes running the Power On Self Test. You may have firmware issues with the switch and/or the switch is stuck in initialization mode. You may have to contact 3com regarding a warranty issue. Hope this helps. Good luck.
Posted on Jun 21, 2007
  • 47 Answers
SOURCE: Link and activity lights on 3Com Switch ports without connection
Do the ports work when the cables are connect?  I did some re-search and this seems to be an ongoing issue with 3com switches.  It should not effect the use of the switch
Posted on Oct 27, 2007
motaro
  • 449 Answers
SOURCE: Uplinking Using Gig Copper
hello, use the plugin modules for the rj 45 connection port to uplink it.
Posted on Aug 04, 2009
SOURCE: Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
Posted on Jun 08, 2010
th3xer0
  • 25 Answers
SOURCE: I have forgot my admin
Search the following documents for 'Password Recovery':
http://support.3com.com/infodeli/tools/switches/4500/s3n03_01_00sp01_readme.pdf
http://support.3com.com/infodeli/tools/switches/4500/3Com_Switch_4500_Command_Reference_Guide.pdf
Both of these document discuss the password recovery process for this device.
Posted on Mar 02, 2011
9K4FBXPC45D0D
Courtney,
3Com has purchased by HP so go the the HP website and lookup the warranty entitlement of your 3Com equipment here and submit an online RMA request.
HP Networking support and look up tool
Jan 13, 2014 | 3Com Switch 4500 PWR 26-Port...
I want to know the default ip address of 3com superstack 3 switch 4500 model and the default username and password of the device
Username:monitor Password: monitor---monitor mode, view only manager manager--can change all except security features admin (no password)--sets security features IP: 169.254.100.100 or 169.254.100.99
Jul 18, 2011 | 3Com 4500 24-Port Ethernet Switch
I have a 3com 4500 connected to 2 5500s (A & B), which are the the GWs for the 4500. I issued on the 4500: ip route-static 0.0.0.0 0 192.168.0.254 preference 60 (5500 A) ip route-static 0.0.0.0 0...
From your scenario what i guess is the two 5500's (A&B) are connected to each other also. Thats why the link between B&4500 is remaining down due to STP ( to avoid Network loop).
Please correct me if I am wrong.
What is the status of the link connecting 4500 to 5500 B when 500A is active and when 5500A is down .
If you are running STP i will suggest you to wait for 2 minutes after 5500A goes down and STP will be recalculated and the link connecting to 5500B will become active and then the route will also become active.
Best regards
Nov 02, 2010 | 3Com 4500 24-Port Ethernet Switch
How can configure trunk
not sure about the 3COM side, but on the Cisco side... go to the configure prompt, then the port that you need to trunk (int [interface name and number] and enter)
Once you are in the interface, use the following command:
switchport trunk encap dot1q
switchport mode trunk
Then make sure that the interface is not shut down, connect the switches together and (hopefully) the 3COM will negotiate to trunking... if not you will need to manually configure the 3com.
Hope that this helps!
Jan 07, 2010 | 3Com Switch 4500 PWR 26-Port...
Aug 04, 2009 | Computers & Internet
Oct 28, 2008 | 3Com 4500 24-Port Ethernet Switch
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
Jul 25, 2008 | 3Com 4500 24-Port Ethernet Switch
Computers & Internet Logo
564 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
