Question about KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher
I have a Kitchenaid 9741068h whisper quiet. It fills heats and then the cancel light starts to flash. it sounds like it wants to start but will not kick over. I can hit cancel a couple of times and it will work after several attemps. any help out there?
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Posted on Mar 25, 2008
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Posted on Jan 16, 2009
  • 530 Answers
SOURCE: Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Posted on Apr 14, 2009
erpaalai
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
SOURCE: Child lock blinking on a Kitchenaid ultima diswasher.
Try holding the E.S. button down for 30 seconds. Does not work, you need an Electronic control assembly which can be ordered online from Repair clinic .com for $146 for your model plus shipping. This is apparently a common problem with Kitchenaid dishwashers. Just repaired one the other day. Tried everything, but as soon as the new Electronic control assembly was installed, everything was Okay. This is an easy repair for anyone who is handy at all. Please shut off power to the dishwasher by switching the breaker off or removing the fuse.
Posted on Feb 20, 2010
Kitchenaid whisper quiet plus dishwasher
It is likely the thermal fuse is cut off and will need to be reset or replaced depending on the model number of your dishwasher. Please provide actual model number in the comments.
Apr 25, 2014 | KitchenAid Dishwashers
This could be a bad heating element. You need to check it with a meter to see if it is ok. If it is ok then you may have a control board issue. There is a technicians guide stuck to the machine if you take the kick panel off you should see it sticking to the frame or the back of the panel.
Jul 09, 2013 | Dishwashers
My kitchen aid whisper quiet dishwasher will not start and the clean button is flashing
The flashing clean light is an indication that the water did not heat properly. Follow the link below to some instructions I put together that will show you how to reset the control so you can use the dishwasher again and what may have caused the error. Let me know if this is helpful.
Clean Light Flashing
May 22, 2010 | Dishwashers
Clean light won't go off and cannot start another
you need to pull the dishwasher out and check your heating element.
to remove code hit heated dry and normal wash and toggle till all the lights light up and then hit cancel this should clear your code.
there is a problem with the heater or the heater curcuit
let me know how it goes
Jan 13, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Flashing clean light and wont start. Is there a sequence of buttons to reset the switchboard?
sani rinse---heated dry---sani rinse---- heated dry.. all the lights on console should light then close the door, let run for 20 -30 secs, and cancel the cycle, if the problem happens again yo need t call a servicer. 1 time maybe a fluke but to happen again indicates a heating, issue somewhere(or a lack of heating)
Mar 04, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
KitchenAid Clothes Washer, Fills and then Hums, Blew Breaker
no, need to empty water theres enough room to pull to side, and yesathought it spins by hand i like to see it spin under load. its possible you have a bad capacitor
Jan 31, 2009 | Washing Machines
Open Questions:
See all KitchenAid 24 in. KUDI01ILBS Stainless Steel Questions
KitchenAid 24 in. KUDI01ILBS Stainless Steel Built-in Dishwasher Logo
442 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
