Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a '05 Cub Cadet Tank 60 Commercial ( I only use it on my three acres). I have 2300 hours on it. It runs, I don't have any trouble starting it, I have a new battery, It's like new!!! Last year after running it awhile I notice when I disengaged the pto switch to get off of it to move or pick-up some thing, when I got back on, engage the pto switch, the blades would not turn on, I headed towards the garage and it would suddenly turn on, if I bounce on the seat, it will turn on. Any Ideas, Thanks
  • 1 more comment
  • johnrod11 Apr 07, 2011
    Thanks for a starting place. I have removed the cover and jiggled and wiggled the wires and they seem to be stiff and tight and connected, I have disconnected and put back together the connections on the sensors, (7) and still no luck. Is there a way to test the pto switch, do you know the color code of the wiring, any other suggestions? Thanks John
    I'll try this approach some time within the next few days,,, my job keeps me busy, I'll let you know when I complete this test. Thanks John
  • johnrod11 Apr 14, 2011
    Hi Azraelsrl, I'm back to give my work/ not working switch another try,
    I took the PTO switch out, it looks like new so does my wiring connector, no rust, no corrosion.
    I'm not sure how to check continuity on this seven blade switch. My son is an electrical engineer and he will be coming over to try and help. I have all the books that came with the mower.
    I'm reading this; Page 18 of my Operator's and service Manual.
    The air gap should be checked every 300 hours The air gap should be checked with feeler gages in the three slots of the BBC.
    The air gap should be adjusted to 0.013" to0.015". There are three inspection slots i the brake cover. To adjust, successively tighten each of the three gap adjustment nuts an equal amount. Insert a feeler gage into each slot as the air gap adjustment nut are tightened.
    The correct adjustment occurs when slight contact with the feeler gage occurs.
    Engage the BBC a couple of times, and recheck the air gap.
    Can you translate this for me?
    Where are the air gaps located?
    What is BBC? Thanks, John
  • 11,800 Answers
Most likely the switch itself is at fault: the metal blades inside it that make the contact have prematurely lost their elasticity and the contact becomes ify. You will have to replace the switch.
http://www.lawnmowerstuff.com/087-Cub_Cadet_Electrical.html
It just pops out of the dash and the cable just plug in - move the cables one at a time with the battery disconnected.
Posted on Apr 06, 2011
  • 1 more comment
  • Azrael SRL Apr 07, 2011
    The switch is easy to test: just take it out (make a schematic with the wires first) then just test the continuity between plots, with and without the switch pressed.
    Here is a very similar wiring
    http://i341.photobucket.com/albums/o368/...
    OK.
  • Azrael SRL Apr 14, 2011
    The BBC is the clutch of the blades power wheel - it's the part that transmits the power from the motor to the blades when needed. In it there is a electromagnet that is commanded by the PTO switch. When the switch is pressed it sends power to the electromagnet which in turn press some shoes on the drum/cover of the wheel. In time these shoes wear out and they need readjusting - if the space (here called air gap) is too large they will not make sufficient contact and the blades won't spin. It's the same stuff like on a drum brake in an old car. To adjust the gap you follow the instructions
My z force 60 cub cadet starts and runs until you drop brake or drivers arms or turn on pto then it kills.
Check in to the deadman seat switch. Sounds like the safety systems are kicking in, make sure your sitting on the seat. Check plug.
Apr 21, 2017 | Cub Cadet Garden
Cub Cadet XT1 Kohler Engine Stall
Most likely your cap is not venting properly, replace the cap.
Sep 03, 2016 | Cub Cadet Garden
My 04 cub cadet m60 tank with a 27hp Koehler just up and quits after 20 min. I just changed oil and filter and "change oil " is blinking. Help
I'm not a Cub dealer but the "change oil" light should reset itself after usually an hour of use. check the oil level for the no start. if it has an oil level switch and is low, there will be no spark.
Jun 01, 2016 | Cub Cadet Garden
I have a cub cadet tank 60. It just shut off.
make sure it has gas and spark at plug if dose then take some starting fluid and sqiurt in it start it if runes rebuild carderator or seafoam fuel additive it cleans carbs excellent stuff add 4 cap to 3 gal tank let run three tank fulls through it most of the will run fine but sometime if carb to dirty have to rebuild carb and make sure no water in gas only use fresh gas sitting gas can get dirty
Aug 30, 2014 | Garden
Cub cadet dies 20 minutes after starting
Slacke off the fuel filler cap when it starts to die, if it picks up again the fuel tank breather is blocked.
Apr 13, 2012 | Cub Cadet Garden
Mower will start up cold, i will mow for a half hour then it sputters and dies. After it sits for a while and cools it will start again, but not as easily as the first time. It will again mow for a while...
The valves DO NEED adjusting every 250 to 300 hours of service. That is why it dies out beleive me. It is not that hard to do if you have a service manual to help you along to perform this task
Jul 09, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have a cub cedet commercial tank 60 zero turn lawn mower, and i need to change lawn mower blades. Which way should i turn the nut to take the blades off.
As viewed from the bottom, if the blade turns clockwise, then the bolt should have a left-hand thread. A possible exception would be if the blade cannot slip relative to the shaft. This could be the case if the blade (not the washer) has a D shaped hole in it.
Good luck, Al K
Aug 26, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
59 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
