Question about Symphonic Televison & Video
Tv cuts off
OK...we broke the vcr in the tv/combo symphonic. the tape would NOT eject because something inside broke. so we had to go inside and naturally make it worse. from the time the tape stuck the tv combo would stay in the eject mode and then withing the seconds it would turn the tv off.
so we went inside and tore the mess up worst. NOW...my question is this...you can look inside and see the left facing reel still turning...is there anyway of making the tv to stop recognizing the broken vcr so that the tv will stay on. ...is there any wire we can disconnect inside...otherwise we have a perfectly good tv we will have to throw away ...because some sensor is telling it to eject a tape from a broken vcr.
I will probably never find this site again...can you email me direct?
sheliafaith@comcast.net
Being it was older and a left over gift....we trashed it and saved my husband's blood pressure.
Posted on Aug 06, 2008
Vcr stuck on eject and poiwers off right away
Chances are that something has become damaged inside the unit and as the unit can't get out the tape, powers off to stop any further damage. The only solution will be to remove the video by entering the unit. As this is a TV unit care should be taken of the high voltages connected with the TV part. And should only be undertaken by someone with experiance.
Feb 09, 2013 | Symphonic SC-3813 13-Inch TV/VCR Combo
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
Dec 23, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
My grandson was watching an old VHS tape and pushed something. Now, all I see when I turn the t.v. on is "counter00.00" and then the t.v. shuts off in about 3 seconds. I have lost the owners manual. HELP!
Left up the VCR tape gate,see,if the tape still in there?Yes,unplug,10 mins.replug the Tv and push the tape forward botton.Let the tape go forward about 5 sec. eject the tape take out.Grandson probally rewind the same seen to many times,causing power power shotdown mode.
Aug 09, 2010 | Symphonic SC3813 13 in. TV/VCR Combo
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
Tape wont eject
Veri8fy that the belt on the side of the VCR mechanism is intact. If it is, then check that the motor works, by appying 12 volts to it,with the belt disconnected. If the motor works, it might be that your mode switch needs cleaning, and that takes some fancy unsoldering and soldering.
Sep 06, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
Jul 10, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Tv vcr combo
The best way I can think of is to REMOVE the rubber band that loads the tape into the transport unit.Be KILLFULL (careful) the band is right next to the B+ (power supply) or the A\C 120volt
( and if u can find the replacement rubber bands, buy 2 kits)
Nov 16, 2007 | Symphonic SC319C 19 in. TV/VCR Combo
TV Problem
i have this problem too i dont know how to fix it either
Nov 12, 2007 | Symphonic SC319C 19 in. TV/VCR Combo
Televison & Video Logo
131 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
