Question about RCA RCR311B Remote Control
RCA RCR311B Remote - none of buttons work - when pushing them the ON-OFF button at the top lights up red.
    Top Expert:
  • RCA Master
  • 75,417 Answers
Hello
if the top light lights up, the remote controls' internal circuits are working properly. Check its infrared light emitting diode at its front, which sends infrared signals. Tthat diode may be faulty, or its soldering joints inside may got loose. Open it and check. OK.
Posted on Apr 06, 2011
Rcr311b remote won't code to Sansui tv
Try a code search method.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out
Jun 27, 2012 | RCA RCR311B Remote Control
Dont know code # my rca remote rcr3273n or the sequence to program it for a rca tv
Make sure the device is on. Hold down the tv (or whichever device your trying to program) button first and then the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly letting it flash until the device turns off. Then press the stop button...and it is programmed.
Nov 26, 2010 | RCA RCR311B Remote Control
I tried to change the channel and doesnt work anymore before the problem the red power light was on
i accidently hit the guide button. now i can't do anything with it.no sound or channels.my tv is an emerson,my device is a #6.ijust bought it about a month ago. thanks
Nov 08, 2010 | RCA RCR311B Remote Control
Can not control the volume on an rca
Ok to reprogram the remote and this only works if you just use the remote for the tv and the receiver. Like i was saying to reprogram the remote hold the tv button till all the top lights flash, then push the red power button, then hit the up arrow button slowly til the tv cuts off, once it cuts off hit the pound (#) button. The top lights should blink three times, that should reprogram the remote, If it is a tv/vcr combo or a tv/dvd combo then there isnt a code for it. Also there is a series of years that the rca tv's wont take a full code and u can just control the power and the tv channel
Sep 05, 2010 | DISH Network IR Remote Control
Im having problems programing my sansui flat screen tv when i program my rcr311b universal remote it works up untill the point when the tv turns off after pressing the play button and releasing the reverse...
first wat are u trying to do,,,,,,in mind....wat way,,,,,to do wat....try going to get thing that can remote w/remote to do......reverse the plan of mind,,,,
Aug 27, 2010 | RCA RCR311B Remote Control
I have a remote control for an RCA tv,,, and i want to know what button to push to change it to video 1 and video 2
The "input" button should change between video 1 and video 2, depending on how your tv was programed. Good luck! Der Strom
Apr 27, 2010 | RCA RCR311B Remote Control
My input button not working on my rca remote for sanyo tv
Under you key pad, there is a piece with what
appears to be rubber buttons. When you press a
number or feature on your key pad, this button
comes into contact with a circuit that complete a
Jan 20, 2009 | RCA RCR311B Remote Control
Plz help
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.
There are a ton of codes for the Philips and Magnavox TVs. Your best option is to go here to find the codes:
http://remotefinder.rca.com/default.aspx?site=rcacgi?file=others/rca/rcr311-manual.zip&area=other
Basically, hold the tv button. While holding it press the 4 numbers in the code. Then let go of the tv button.
Oct 07, 2008 | RCA RCR311B Remote Control
Need help
press the stop button on the remote to save the proper code
Dec 02, 2007 | RCA RCR311B Remote Control
RCA RCR311B Remote Control Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
