Question about Samsung Healthy Living Bsp 4007 Premium Deluxe Thinline See Thru Flat Screen Blood Pressure Monitor With Irregular Heartbeat Detector
Samsung model bsp 4007 after changing batteries all i get on screen is ep
How I make factory reset for Samsung dvr model ep 10-000522 wen I forgot my password
try to find reset button on the main board of the device or remove the battery on the same board
Dec 21, 2015 | Samsung Home Security
Hi i would like your help to open the region of BD-d7500-zf
There most likely isn't any easy-to-perform user setting that can open up the unit to multi-region capability. The entire reason for region codes was for anti-pirating issues in the first place. You can CHANGE the region code to allow you to play other regions DVDs and such, but most units are limited the 2 or 3 changes and then stay wherever they are. This allows users, if they relocate to another area, to make their unit compatible with the media in their new locale. If it were easy to unlock the units, then there is no purpose in the region restrictions in the first place. Most often, what you want to do requires a firmware hack that can be tricky to do, and can render you machine worthless is the hack you download and try fails.
Jun 18, 2015 | Televison & Video
Monitor Bsp 4007 which number should i view for my bloodpressure
This is pumping motor problem / kindly follow the rules when you are taking the bp test
Sep 10, 2013 | Samsung Healthy Living Bsp 4007 Premium...
Pumps up to 80 but stops
Have you tested the "bladder" for leaks? Sounds like there is a leak and once the pressure reaches 80 it can't hold any more air. If you have the receipt, take it back to the store where you purchased it and ask for a refund or for an exchange.
Aug 26, 2012 | Samsung Healthy Living Bsp 4007 Premium...
When attaching the end connector to the cuff hose, it was done incorrectly. to correct it made the hose about an inch shorter. Does this change the accuracy of the readings?
no..... The machine is operated based on pressure, no matter how it is there, so short or long, you just have to make sure the cuff is big enough and you are fine..... Guy
Sep 04, 2010 | Samsung Healthy Living Bsp 4007 Premium...
Can I get a replacement 13-17 inch cuff for this machine?
yes, the actual website sells them as does ebay and amazon
Aug 19, 2010 | Samsung Healthy Living Bsp 4007 Premium...
Need new cuffs
You can get them online at ebay or amazon
Jun 20, 2010 | Samsung Healthy Living Bsp 4007 Premium...
Power Acoustik PTID-4007 Okay, so I checked my radio fuse, it's fine. Checked for constant and acc 12v. and they are there. fuses on harness are good. I spliced my adapter harness onto the PTID-4007...
i have Power Acoustik PTID-4007 my problem is not turn on lcd not out audio but yes is take cd and out cd, the screen is move in three postion. help me please
thanks
Mar 08, 2009 | Power Acoustik PTID-4006T Car Video Player
Samsung Healthy Living Bsp 4007 Premium Deluxe Thinline See Thru Flat Screen Blood Pressure Monitor With Irregular Heartbeat Detector Logo
67 people viewed this question
Top Samsung Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Joe Ball
Joe Ball
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
