My hdd hd 161hj is not working i wants to know its warranty status but model no is not samsung warranty check performa. it S/N is - SOV3J90Q923065
  • Brian Sullivan
    Brian Sullivan Apr 06, 2011
    how old is the hard drive
  • 80 Answers
If a hard drive has failed within one year of the purchase date, then it will be covered under warranty. If it is beyond one year, or the problem is not with the hard drive itself but instead with the operating system that is installed on the drive, then it will not be covered under a warranty.
Posted on Apr 06, 2011
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
S/n-S24PJ1WZ302809, WARRANTY CHECK.
To determine the warranty status of your Hard Drive, you should go to Samsung's Warranty Check utility ( http://www.samsung.com/in/support/warranty/hddWarrantyCheck.do?page=HDD.WARRANTY.CHECK) and enter your device serial number.
Mar 03, 2011 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
I need ti know the warranty period of my laptop bcz iam going to sell...( Sl no: 275202857004512, Service tag no:- c603u12s )& also i need to know how much rupees i can get if i sell this laptop....
All the VAIO computers are shipped with a limited 1 year warranty.
The detailed information on Sony Warranty is available in the below link.
http://esupport.sony.com/US/perl/support-info.pl?template_id=1&info_id=28
Refer your purchase receipt or contact the sony support team to get the exact warranty status. Provide them with the model # of your computer.
Nov 19, 2010 | Sony VAIO VGN-S460 Notebook
Hi dear Expert. I Have my MB ASUS M2A-VM HDMI. SATA1(0) was connected with HDD Samsung 320Gb. SATA2(1) was connected with CD drive. Other ports spare. Now by commecting new HD Samsung 1Tb on SATA3(2)...
If the new Drive is setup on a different channel than the First HDD and CD then it should be set to Master. In the Bios you probably need to activate the second SATA channel so the Auto Detect Function can work. You also need to check that the MB can support a drive that size. Not all MB will support an HDD of that size. Aside from the Obvious of checking all your cable connection to insure that they are all solid the only other thing I would recommend is that you switch the CD and new HDD positions. Put both HD's on the same SATA channel and the CD on the Separate channel. This would require making 1 HD a Master and the other a Slave and changing the CD to a Master since it will have it's own Channel. Second, try remove all but the New HDD from the system. Set the New HDD up as the only HDD and see if the BIOS will see and allow you to select it. If it will not there is a problem either with the size of the HD or with the HD itself.
Sep 23, 2010 | ASUS M2A-VM (0610839149438) Motherboard
How to find my hdd warranty??
If you want to know the warranty of your hdd then click the below link and fill the details and check your warranty
http://support.seagate.com/customer/warranty_validation.jsp?form=0
How To Find Model and Serial Numbers
If your drive is connected to your computer: Seagate has created a very simple tool that will tell you the serial number and the model number of any and all Seagate and Maxtor-brand drives connected in or to your computer. Use the DriveDetect.exe method to find both numbers.
You can also use SeaTools to display each number.
(See below if you have a Mac computer.)
If your drive is not connected to your computer: See the flash-based Serial Number locator tool to find your serial number and model number (and/or occasionally the serial number and the part number) on the drive label.
Please rate me if this solution works for you
Thanks......Have a great time
Jul 01, 2010 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Hard disk Warranty
Contact Samsung
Model: Samsung Spinpoint SP0802N
Call 1-800-SAMSUNG (1-800-726-7864)
Jan 10, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
No recognized by any PC I try to plug in
Hi are u sure the hard disk was not complitly full if yes try to use anothe backup software such as easy recover pro or so and copy all the data from your hdd to another location but befor udo so please be sure
1. shut down your system shut down the hdd plug the power properly to your hdd and connect the usb or firewire then connect the medium to your system and start the hdd and then start your system ...if it detected its fine...
2. if still dosent detect check in disk management by right clicking on my computer icon go to manage and then disk management if u see the hdd over there and showing status a forigen just right click on the word and say import forigen disk .and should work
if the status shows unalocated right click on it and say intialize hdd ..
if shows helthy and be sure have a drive letter on if not then please right click on the hdd strap and say add or change drive letter and use any abailable drive letter
thanks
good luck
Aug 27, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Computers & Internet Logo
David Payne
David Payne
