Question about Kenmore 24032\24036 Top Load Washer
I have a Kenmore 70 series Model 110.26732500 When I wash clothes in the heavy duty mode everything work fine till rinse mode. After it washes it drains all the water and keeps on spinning and does not go into rinse. I have to turn it by hand then works fine. Plus is I do a different wash mode it works fine just does it when I do heavy duty mode.
  • 113 Answers
SOURCE: belt replacement on kenmore 70 series heavy duty plus
No belt on this, its a direct drive with a motor coupler..There is a tutorial for this at www.shop.washermd.com Dave
Posted on Jan 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Posted on Feb 26, 2009
  • 17 Answers
SOURCE: Model 110 top loading washer will not spin
check belt
Posted on Apr 10, 2009
SolutionGuy
  • 331 Answers
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
Posted on May 02, 2009
  • 64 Answers
SOURCE: Kenmore 70 series washer: leaky water pump
NEW WATER PUMP
Posted on Aug 31, 2009
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
Feb 19, 2012 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Feb 21, 2010 | Washing Machines
What is the capacity of my Kenmore 80 series Model 110 washer?
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches
Sep 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
Feb 25, 2009 | Kenmore Washing Machines
How to work my washer?
the timer change by itself. You don't have to change anything.
But cold rinse only works if you have the cold water connect to the washer
May 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
65 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
