Question about Refrigerators
The RT30MBSS freezer works fine but the lower compartment is not cool even when setting is at the coldest. What can be done to fix the problem DIY?
  • 9 Answers
SOURCE: Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Posted on Sep 06, 2008
Maytag317
  • 1136 Answers
SOURCE: cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
Posted on May 13, 2009
BIKER T
  • 909 Answers
SOURCE: my whirlpool ET8MTMXKQ01 'runs' but suddenly stopped cooling
Switch off completely for a day and give a good defrost. If when you retry and it still does not cool,(assuming the compressor is running) then you have either got a blockage or an internal leak. Need to then get a technician to sort out.
Posted on Sep 21, 2009
  • 143 Answers
SOURCE: freezer is fine but the lower compartment is just
Firstly turn you temperature setting to the MIDDLE in between cold and coldest. This will allow cold air coming from your freezer to go into your fridge. if this does not seem to change your problem, check to see if the air vent at the back, top of the fridge is allowing air to flow from the freezer to the fridge. if there is no air flowing there may be a clogged ice drain or pan. usually if this is clogged you can unplug your fridge for 24 hours with the doors open. and it will manually melt the ice buid up.hope this helps
Thanks
Posted on Oct 12, 2009
heatman101
  • 43501 Answers
SOURCE: Fridge not cooling, freezer not freezing even on coldest settings
From what you are describing, you have a refrigerant leak. The freon has leaked from the system, The compressor will still run and evrything looks fine. To double check you will have to have someone hookup gauges to the system and verify that the charge is lost.
It may be possible to find and repair the leak. This is not always possible as some of the system is virtually inaccessible in many refrigerators.
Make sure if you do have someone repair the system that they evacuate the system very well and do a good vacum test before recharging the system.
This should help you to solve your problem.
Thanks for using Fixya!!
Heatman101
Posted on Nov 24, 2009
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Fridge section of fridge freezer not cold despite turning thermostat to max. Freezer section appears to be working fine.
Make sure that if it has a "colder" knob in the freezer section that it is not set all the
way over to coldest. This blocks all cold air entering the lower compartment when
set this way. It actually has been eliminated on some models.
Also you may have ice buildup in the stack assembly that feeds
the lower compartment or even a frozen upper compartment behind the back
panel of the freezer limiting air flow to the lower compartment. Make sure to unplug unit if service is necessary in these areas. I hope this is helpful.
May 02, 2011 | Microwave Ovens
I've had a Samsung fridge for 6-7 years, it's a small/medium fridge/freezer with the freezer at the top (sorry, don;t have the size handy). The freezer works fine, however the fridge no longer makes...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | Samsung Refrigerators
Freezer is working fine but the Fridge part is not
i take it the unit is frost free you need to replace the defrost element in the freezer whats happening is your freezer sends cold air through small holes to the fridge compartment but when the freezer cant self defrost those holes freeze over thus no cold air into the fridge compartment get a tech in to check the element shoulnt cost more than $ 80.00
Apr 21, 2010 | Refrigerators
Freezer is fine but the lower compartment is just cool not cold temp setting is turned to coldest
Thanks
Oct 12, 2009 | Magic Chef Refrigerators
Refrigerator compartment not cooling properly.
Yes The circulating fan behind the rear freezer wall is waring out. The fan with labor and material cost is around $300.00.
Jul 11, 2009 | Refrigerators
Cool compartment is not cold enough
Thanks
Vic
May 13, 2009 | Refrigerators
Jun 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Sep 03, 2006 | Maytag MZD2768G Side by Side Refrigerator
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
