Question about Garden
My stihl 066 starts good cuts great for aprox 1min thenshuts down and will not restat for hr.
    Novelist:
  • 111 Answers
It sounds like the coil is going out. Also there could be some water in the tank and when you are cutting the filter is trying to pick it up and it stalls the engine. If you know your chainsaw well enough you could do the repair yourself, but depending on the age of the unit. It could be under a warranty. Stihl has a 3 year extended warranty that covers the ignition coil. For parts you will need to find a Stihl dealer, you might also ask about them putting on the coil for you. You might see if your unit would be a candidate for a warranty. I've included a link to help you find your nearest Stihl dealer, when you are looking for a dealer I would try to find one that has a Gold Certified Technician. That way if you do not feel that you are able to put the coil on correctly, you will get the best service possible. I hope this helps you out. http://stihldealer.net/locator/
Posted on Apr 06, 2011
Testimonial: "Thanks will check if fire to plug is stoping. had a 038 that sp wire would go to ground same symtom. ever need help on 1950 to1990 big CAT engins [d39"
Hello I have a Stihl 066 chainsaw and I am replacing the cylinder what are the torque ratings for the screws?
When installing screws into used components, gently rotate the screw backwards until the threads on the bolt go past the threads already in the component, then start to gently turn the screw in the tightening direction. (the reason is: you do not want to cut new threads, as this will damage and remove the current thread material, and the hole will be too big as a result)
Put a small amount of lubricant (oil, thread oil, ect) and proceed to tighten the screw(bolt).
In this case 11 ft lb. torgue
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Feb 02, 2017 | Stihl Garden
Stihl 066 cylinder to crankcase torque
Put a small amount of lubricant (oil, thread oil, ect) and proceed to tighten the screw(bolt). 11 ft lbs in this case.
Will a 56mm cylinder kit fit a 064
http://sawparts.ca/products/stihl-064-066-ms650-ms660-big-bore-cylinder-kit-nikasil-56mm
It seems that YES a 56mm aftermarket cylinder is available for the Stihl 064. Looking at the kit you need to just replace Cylinder, Piston and rings, bearing bush and clips. Worth also replacing the base gasket too.
May 01, 2016 | Stihl Models 064, 066, Ms640, Ms660
Does a stihl 064 flywheel fit an old stihl red eye 066
What's a red eye? If the first four numbers from the old flywheel match up with the ones on the replacement, they should swap. I'd suggest just getting the correct one instead of trying to jerry-rig a chainsaw. eBay is a great resource for used parts and they're usually fairly cheap.
Oct 23, 2012 | Stihl Garden
Sthil 066 carb diagram
Don't mess with the insides of a STIHL carb, just buy a new one. Why put new parts in an old carb?
Jan 18, 2012 | Stihl Models 064, 066, Ms640, Ms660
Sthil 066 chainsaw
You are absolutely right, an 066 is a STIHL model chainsaw. Good job!
Looking for a parts diagram for a stihl 066 chainsaw
The one with the two right angle connectors is the inlet line. The other is the return line
Nov 05, 2011 | Stihl Models 064, 066, Ms640, Ms660
Garden Logo
191 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
