Question about Cameras
MY COMPUTER DOES RECOGNIZE THIS usb DEVICE - Cameras
  • 90 Answers
Sir you are facing that problem because you haven't install the driver software.Please try after installing the driver software.Then it will be OK.
Posted on Apr 06, 2011
Need driver for verbatim pocket reader, model 97709
This device physically connects to a computer through a USB port, and operates via one of (3) standard protocols. No separate driver software is required or needed. If your computer does not recognize the device in one USB port, you should try to connect it to any/all of the other available USB ports. If your computer still fails to recognize and operate your device, the device is probably in need of repair.
Oct 07, 2014 | Computers & Internet
Tip
USB DEVICE DOES NOT recognize
Issue:: USB DEVICE DOES NOT recognize
___________________________________
Manual Troubleshooting for this issue::
-Open device manager
-Right Click on USB Root Hub
-Choose Properties >>Selet Power Management
-Remove the Tick Mark Before "Allow the computer to turn off the power if device is not in use..."
-Do the same for all USB ROOT HUB
-Then Uninstall all USB ROOT HUB
-Restart your computer , USB device will be working.
on Jun 21, 2010 | Computers & Internet
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Im tryin to connect my USB in the computer to put my pictures on the computer but it wont let me ???/
Hello
A few questions that may confirm problem.
Does your computer seem to know that something is plugged in?
Or does it say that it does not recognize the device?
Well, if the computer actually knows that a device has been plugged in, but you just cannot see the device in my computer, here is how you fix that. Just follow these steps:
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your device presented in the schematic below.
Right click on the device and assign a new drive letter.
If your computer states that it does not recognize the device, try plugging it in one of the back USB ports of the computer. Please rate this.
Best regards
Sep 30, 2009 | Dell 210W Optiplex GX270 NPS-210 AB Power...
Computer doesn't recognize device
remove previous all drivers for this device and install again, if not works , setup your OS freshly.
Sep 26, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Usb is not recognizing plug-in
may the usb device in your bios is disable. you must enable the usb device in your bios to recgnice your usb. you must enter to the bios setup to config. the usb configuration.
Apr 30, 2009 | Computers & Internet
Computer doesn't recognize usb device...
do not use Front usb connector. put your device in backside of CPU usb port. it wil work fine.
Mar 05, 2008 | Belkin BLKF5U201 USB Peripheral...
Computer Won't recognize MP3/MP4 Player
Go to device manager. Remove all USB ports. Re-boot. See if that workds.
Dec 20, 2007 | Samsung YP-T8 Digital Media Player
Cameras Logo
24 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
