Question about Samsung Washing Machines
I just put in my first load of clothing in my new machine. It does not seem like there is enough water flowing into the machine. I cannot see a water line while the clothes are being washed. It seems to me that the washer should at least be half full of water while washing.
    Scholar:
  • 125 Answers
If this is a HE unit it's probably fine. Front load units determine how much water to add based on how big of a load you put in. As long as water is flowing (waterfalling) over the clothes as the machine tumbles then it is fine. Try a larger load and see if the water level increases.
Posted on Apr 06, 2011
Well I do have a problem with the drainage, the pipeline will over flow whenwwashing machine is draining water out but I have ran a snake down it and didn't seem to find a clog. But the water splashes out...
There must be enough air allowed into the drainage pipe in order for the water to go down...Apparently there is not enough air entering into the drainage line to allow the water to flow quickly...Check the vent pipe on this drainage line. If these are new machines you may have to increase the diameter of the pipe so that displacement can occur as fast as the water is flowing.
Feb 25, 2015 | Washing Machines
I have been putting my washing on a 40 wash and have been putting enough washing liquid in but my clothes just will not wash, i have felt the glass in the door but it doesnt get very hot, is my washing...
The hot water goes into the machine at a slower rate than the cold water does. Open the hot spigot (water valve) behind the washing machine all the way open, then open the cold spigot just enough to get the desired 'warm' temperature of the water going into the machine while the machine is filling. You may have to shut the door to allow water to flow. Remember that it takes a minute or so for hot water to reach the machine from hot water tank.
Dec 08, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Water
its probably normal as new machines now only put in enough water to saturate the clothes its only the rinse or wool/delicate cycles that use a higher water level
Mar 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
Maytag washer PAV2300 water over flow
from what I am reading on-line, it is the mix valve, aka water valve. Unplug the washer, then see if it still fills. If so, it's most likely stuck open, and needs to be replaced. about $22.00
Feb 21, 2008 | Washing Machines
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
Fabric Softener remains after load done
You should make sure that your inlet to the machine flows with rather good pressure. I tell u this for your soft tray requires water, also your rinse.
Nov 14, 2007 | GE WBVH6240F Front Load Washer
Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Oct 12, 2007 | Crosley CAWC529JQ Top Load Washer
Washing Machines Logo
80 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
