Question about Whirlpool Washing Machines
I have a Whirlpool washer. It will fill and run through the first cycle and then stop... What would cause this?
  • 91 Answers
I would pretty much guess it's a faulty heating element. After the machine stops after filling with water and running a while to get the clothes wetit stops to heat the water. Listen carefully to hear the water heating up, it sound simular to an electric kettle. If this does not happen the program is unable to advance.
Posted on Apr 06, 2011
WhIzAtIt
  • 136 Answers
SOURCE: whirlpool ultimate care II stops during cycle
THe most likely cause for this is either the lid switch or the timer itself sticking.
Posted on Sep 14, 2007
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
robocop
  • 90 Answers
SOURCE: whirlpool washer wont spin during high spin cycle
Try www.Repairclinic.com.
Posted on Jan 19, 2009
  • 99 Answers
SOURCE: WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Posted on Feb 06, 2009
  • 4044 Answers
SOURCE: whirlpool commercial washer stopped running mid
If the timer and lid switches are funtional and the machine is filling and shutting off correctly that only leaves the motor. Have the motor tested or replace it. Even though the timer is running it is possible that it is still at fault. If you have access to another timer try switching them to make sure it isn't the timer. This does sound like a faulty motor and I would start with that assumption.
Posted on Oct 30, 2009
Whirlpool washer WTW57ESVW0 won't fill with water. I bought this machine two months ago was working fine and then just stopped filling water. Spin cycle and drain cycle work but it won't start fill...
Solution for WTW57ESVW0 Whirlpool Washer that won't fill or agitate, but will spin and drain water.
Replacing the Auto Load Sensing Switch (W10177795 - Illus. No. 12 on Control and Rear Panel Parts) fixed the problem.
In addition, a defective switch can also cause the machine to start agitating while it is filling.
It is relatively easy to replace and there are online videos that can help with the replacement.
Oct 27, 2010 | Washing Machines
I have a 15 yr old Whirlpool washer that has run great. During a cycle, it stopped full of water. I moved the dial around to different areas pushing it in and out and got a cyle to run long enough to pump...
Not always a Timer issue. could be stopping at the cold fill part of the cycle which is the 8 o clock position on the dial. This would be fault with the cold fill vavle.
Sep 15, 2010 | Whirlpool LXR6432JQ Top Load Washer
Cycle stops motor hums whirlpool top load
bad points in timer or bad motor take the motor out and to a used washer shop and see if they will test it for you for a small fee if it tests ok get a timer
Dec 25, 2009 | Whirlpool Washing Machines
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
Whirlpool washer LSQ9264HQ
Either you have a faulty water valve, which would either need to be fixed or cleaned, or you have constant power to the valve caused by a problem in the controller which does not allow the cycle to advance. If, as you say, it does not overfill, then apparently your water level control pressure switch is operating and causing the pump to turn on and drain as fast as it fills.
Feb 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Keep getting SL error code
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer failure
Sep 27, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool ultimate care II stops during cycle
Sep 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
