Hoover 800EL Top loader will fill and empty but will not spin? Making a whirring noise like it is trying to?
  • 91 Answers
Try replacing the large capacetor. This is called apon to give the motor the kick it needs to go into spin. For reference I include a picture to help you locate it.Hoover 800EL Top loader will - sparkyuiop.jpg
Posted on Apr 06, 2011
Washing machine won't wash when on large cycle
without stating the make and model it makes it harder for us to help you figure them out .front loaders are more prone to this type problem than top loaders .could be the gear box is going bad or a belt getting stretched
Oct 06, 2015 | Washing Machines
My Hoover 500M top loader is very noisy on the spin cycle intermittanly. It sounds like a faulty or dry bearing, maybe when the water pump is emptying the bowl. The noise stops as soon as the spin cycle...
First I would bench check the water pump and see if it is operational or not. If it is then I would check the transmission. When it is in the spin cycle it switches to the high speed, so if you hear the grinding only in the spin cycle it could be the high speed gear.
Do you have any indication of a transmission leak? Fluid on the floor or on the transmission?
Jun 22, 2011 | Hoover Washing Machines
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a top loader hoover 800EL,cold and hot water is coming very slow , I am suspecting the solinoid valves is it easy to replace them ?
when you put it on warm does it do the same thing?see if you can hear the solinoids ,they sould not be loud if they are they are bad,is your water presure ok?the valve is easy to replace it has to leads and alittle feed hose,just remove from back of water,(2 screws and replace)mike
Sep 05, 2008 | Hoover Washing Machines
Hoover 800el not spinning
hi all, I have a hoover 800el washing machine and it's making a clicking/ratchet noise. any idea what's causing it?
Kind regards
Louis
May 18, 2008 | Washing Machines
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
