Question about Acer Aspire One PC Notebook
RAM is low, my diagnostic suggests I upgrading my RAM for better performance. How do I do this?
    Scholar:
  • 77 Answers
RAM or memory is a physical component that needs to be installed in your laptop/notebook.
If you are technical enough to do this, you just need to purchase the exact memory module compatible for your laptop and install it yourself. Or, it will be better if you can have a local technician from a local computer shop install it yourself to make sure that it's installed correctly.
Posted on Apr 06, 2011
Testimonial: "quick response, thanks"
  • cglrcng Apr 13, 2011
    First off; Go to; www.belarc.com download the free Belarc Advisor, install & run it, then print the results (A free clean util. that will give you a full hardware/software inventory of the computer). On the right side it will list what RAM is installed in what slots.
    Next, go to www. crucial.com and download the free Crucial System Scanner Tool, run it and print the results. This will give you the specs of what's installed now and all of the upgrade possibilities. (2 free tools). Now you know max. the motherboard will take, and you should upgrade to that maximum if you can afford it. Research the RAM by Specs on E-Bay for Pricing.
    IE: An Acer Aspire One 752 model has 2 slots and takes up to 2GB's in each slot (Total 4 GB..Though less than Vista 64 Bit OS will only recognize and use 3.0 to 3.5 GB's), 200 Pin SODIMM DDR2 PC2-6400(Laptop RAM) Does not require matching Pairs-No ECC (Error Correcting), and a total maximum of 4096 megabytes installed RAM (1GB=Approx. 1024MB), so (4096MB's=4GB's). So you would order 2X2046MB=2 GB's each X 2=$ Gb's Total of PC2-6400 200 Pin 800Mhz SODIMM (Laptop RAM). Currently priced on Tiger Direct new for: 2 X 2048MB ($29.99 Each plus Shipping - Would need to order and install 2=Total upgrade cost $60.00 plus shipping=Cheapest Speed you can buy). It will feel like a new computer after the upgrade if currently has under 1 GB installed and XP/ or under max GB installed Vista or higher.
    Then go to www.acer.com. then drivers & downloads, (Download all your driver updates while there and make yourself a CD of the updated drivers too, make folders for each driver in a New Hardware Folder in "Documents" or "My Documents", burn them to CD/DVD after the install of each), enter your model # and find the Manual section, download the manual, look for upgrade RAM...it will give you instructions to install your new RAM. I usually order based on the specs the Crucial tool puts out from E-Bay, Crucial & or Tiger Direct for best pricing. (Depending on the model, for most laptops the RAM slots are located easy access on the bottom of the case, some are 1 slot bottom, 1 slot under keyboard...Both are replaceable. I personally do a RAM upgrade for cost of RAM + Shipping and a 10%~20% Labor Surcharge. If I am performing a cleanup or any other work on a computer I do the upgrade for RAM cost only.
    Good Luck!
    cglrcng
    Sergeant:
    Champion:
  • 217 Answers
How much memory is installed? I think the module is located under the keyboard and there is only one slot. Your options are to replace the memory module with a larger one yourself, or if you are not comfortable with some disassembly take it to a computer shop. Always remember NEVER take apart a laptop that is under warranty as this will VOID said warranty!
  • 24 Answers
It depends on which model of Aspire One you have. The original model was not designed to upgrade the RAM so the slot is hidden in a place that you need to dismantle the whole machine to access. I have upgraded one but it is not for the non-technical.
Later models have an access panel underneath which is accessed with 1 screw and this is easily done by the average user.
Post the specific model number (D250, etc) and you may get more specific responses.
Posted on Apr 26, 2011
How to make my PC run faster?
I would upgrade your ram to at least 1GB of ram or more, "the higher the better" ram memory will make the computer considerabily faster. Plus a Video Graphics Card with one 1GB of ram will free up resources in your computer and increase performance.
Apr 24, 2012 | Microsoft Windows XP Professional SP3 for...
Pc ddr memory what is the difference between high density and low density
you need to check with board to fine what ram works with first.i use what they say to use so no problems later and save money as well ok jim
Nov 25, 2011 | Computers & Internet
I own a compaq presario 6450nx and I would like to upgrade it. like adding more ram and replace the cpu if its posible, what could be the suggestion?
This is info on your motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07843
Your system comes with Intel P4 2.53 GHz processor and 512MB ram. total ram could be 1GB, bt adding another 512MD stick. You have Socket 478 and processor would be up to you. The system comes with a 200w power supply so, in an upgrade, you should up the power supply. You have an AGP expansoin slot and, you could upgrade to a graphics card but again, power supply is only 200w. The system as it stands is not Windows 7 compatible. If you incraesed your ram and got a graphics card, you would get better performance.
Jun 13, 2011 | Compaq Presario 6450NX (DA238A#ABA-BDL1)...
Which RAM is suitable for Intel presscott 533 motherboard for upgradation
The Mother board only supports DDR1 333mhz or 400mhz
Maximum size of memory the board can read is 2gb in total
I would suggest upgrading to at least a DDR2 Motherboard
May 27, 2011 | Intel Motherboard
How do i upgrade the performance of my 2007 2.0 j20a grand vitara. want to make it more fast and fuel efficient through minimal upgrades.
Some suggestions - performance air filter (free flow type), dual exhaust, low back pressure muffler(s), platinum spark plugs, better plug wires, synthetic oils and fluids.
Mar 05, 2011 | 2007 Suzuki Grand Vitara 4WD
Planning to upgrade my RAM(motherboard K7SOM + V7.5 C
According to the specifications of you PC's motherboard. It supports DDR266 PC2100 type of RAM and only a maximum of 1gb RAM can be installed. If you have 512mb total of RAM right now, it is advisable to upgrade for a better performance of your PC.
Oct 22, 2009 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Cursor of the mouse stops moving while opening pages of any sites n systems hangs frequently
hello sir..
thats boz .. u r runing on a low ram machine, upgrade ur ram.
n also try using upgraded version of internet explorer..
n use only windows application at a time, for better performance.
thank u..
if i've solvd ur problem then plzz plzz plzz vote/rate me..thank u!!
Jul 18, 2009 | Microsoft Windows XP Professional for PC
I wish to upgarde to the fasted CPU possible for my motherboard
More importantly RAM will give you better performance, if your computer is low on ram it doesn't matter much what the cpu is.
you can put up to 4GB of ram into it
4 x 184-pin DDR SDRAM DIMM socket support up to 4 GB
Support DDR400/333/266 unbuffered DDR SDRAM
here is a list of supported CPU's
http://www.ecsusa.com/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=493&MenuID=69&LanID=0
I think any of the dual cores on that page will be a OK upgrade.
So if you upgrade your ram to 2GB and a Dual core 4800+ that should be good. but in the long run it might be smarter to upgrade to a new motherboard and even faster cpu, with DDR 2 memory, the memory ddr2 is really cheap these days.
May 21, 2009 | EliteGroup nFORCE4-A939 Motherboard
Memory upgrade
yeah!! you can do an upgrade as long you know the specifications of your system unit. its ok..it seems that your'e good to go improve the performance ( just don't exceed it to 1GB ot it will crash your motherboard)
Goodluck!!! Have Fun!!
Feb 08, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
